CEG road warrior
CEG road warrior
Posts: 17,248 |
Originally posted by SleeperZ: SC would be my preference for a fun daily driver Contour with a Zetec engine. Of course, in an MTX though.
If had a Focus or a SVT Contour, turbo would be the way to go.
Yes indeed! It is fun.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
Posts: 1,224 |
Plus someone always has a JRSC for sale over on the focaljet forums. Except for the tuning, it's practically a bolt on. Just ask Hector.
Personally, turbo for me. None of that changing pulleys crap to up the boost.
HTH,
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 21,653 |
Originally posted by ZetecChris: on our cars yes.....turbo spools up at a certain rpm usually at 3000....while as a supercharger doesnt, so the power is there from start to finish.....corect me if im wrong guys....
IIRC: you can launch at whatever rpm you need to so you're boosting, and of course every time you shift when getting on it, you'll still be above 3k rpm in the next gear supercharger has a certain rpm it makes full boost at, IIRC usually a lower rpm than the turbo, but it still has to start spinning to really be of use
98.5 SVT
91 Escort GT (almost sold)
FS: SVT rear sway bar
WTB: Very cheap beater
Posts: 1,224 |
It depends on the turbo size as well. A T3 Super 60 will start building boost by 2000rpms and will be at full boost around 4500rpms or sooner. AFAIK, a supercharger doesn't reach peak boost until redline.
Just my .02
BTW, here's a JRSC over at focaljet for $1800. (you may have to register to see it)
BP
Posts: 8,143 |
Supercharger on a zetec? pass  turbo or nitrous would be more cost effective and make more power IMO.
Posts: 1,224 |
True, but you can't beat the ease of installation.
Posts: 2,483 |
Turbo = expensive, hard to install, need to find a place for an IC, hard to tune, and hard on engine (really should upgrade internals). Yes it does produce more HP/TQ than SC. SC = cheaper than turbo or a high power NA buildup, easier install, no IC required, easier to tune, and easier on engine. Nitrous = cheap in the short term but requires refills, very easy to install, very easy to tune, really good power increase, but its not all the time power. NA = for any real power (beyond 170HP) its just not worth it.
Frank McCoy aka Mod-deth aka Mid Life Crisis aka SVT Doood aka mcgainer is a SCAM ARTIST
Pre98 Zetec - Some Mods
Posts: 1,287 |
Originally posted by SleeperZ: Turbo = expensive, hard to install, need to find a place for an IC, hard to tune, and hard on engine (really should upgrade internals). Yes it does produce more HP/TQ than SC. SC = cheaper than turbo or a high power NA buildup, easier install, no IC required, easier to tune, and easier on engine. Nitrous = cheap in the short term but requires refills, very easy to install, very easy to tune, really good power increase, but its not all the time power. NA = for any real power (beyond 170HP) its just not worth it.
nicely done sleeper
Posts: 417 |
must admit i am well happy with the jackson supercharger setup on my zetec. no teething probs (touchwood) and its hardly effected fuel economy like a turbo would have done (remember fuel costs the earth here in UK)
sounds brilliant, and has loadsa power on tap from any revs in any gear. it makes driving normal cars seem pointless!
Posts: 1,287 |
i hate you.....im just kiddin....ive been planning out my funds so i can do one....it should be done by christmas...thats my goal.
