#1336376 07/16/05 02:42 AM
Majisto Offline OP
Going to be changing the fuel filter and was wondering the best way to de-pressurize the fuel system? I pulled the fuel pump fuse in the Taurus and let it run till it died. What fuse is the fuel pump fuse or is there a way to use the fuel switch in the car?
2000 Contour SE
#1336377 07/16/05 03:04 AM
Try the owner's manual...
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
#1336378 07/16/05 03:12 AM
Most mechanics don't bother to depressurize the fuel system before changing the filter.
Any easy way to do so if you feel you must, is to find the fuel pressure gauge attaching port on the fuel rail near the injectors on the engine. It looks a little like a tire valve (to which it is related). Remove the cap and depress the valve core (just like on a tire) with a small screwdriver until it quits spurting, then go and change the filter.
You can also wait about an hour or two and the pressure has usually dropped off quite a bit.
Even with the pressure relieved, you will still spill some fuel. You can't help it when you open the fuel line.
#1336379 07/16/05 05:30 AM
Get small catch pan.
Unscrew the metal clamp.
Pop the two clips.
Let the 4-8 oz of fuel spill out.
Change filter.
Anything else is a waste of time.
