Page 1 of 3 1 2 3
#1336297 07/15/05 10:38 PM
dk616 Offline OP
Hi- I bought my daughter a '95 Contour with the 2.0 Zetec and Auto Trans. I've known the car for about 4-years and it never had a problem with overheating. The waterpump went on it just b-4 I bought it and was replaced. It was ran hot a couple of times so I expected to change the head gasket but the oil+antifreeze are clean so Ive not touched it yet. The problem is the guage say's it's running hot and she claims the CE light has come on. I've replaced the Temp. sensor, sender, resistor in the shroud, and put a 180 stat in it. Also had the rad flushed out. The low speed fan won't come on until it's almost in the Red and I've never had the High speed come on. There is no boiling in the tank and my head tells me that all is OK. How the heck do I know for sure that she's not overheating? I don't want my daughter getting stranded somewhere. Can a car's guages or system go to hell once it's been run hot and not give acurate readings or should I look further? I'm not really sure what to do next! Any suggestions or advice would be greatly appreciated.
Thanks.
95 Contour GL 2.0/Zetec (daughters 1st.) 95 Chevy Lumina 97 Chevy Astro (babe magnet) 91 Sunray 19' bowrider (my money pit)
#1336298 07/15/05 11:06 PM
#1336299 07/16/05 12:58 AM
dk616 Offline OP
Does the OBD-1 give the same info. for a 95?
#1336300 07/16/05 02:19 AM
No.
3-Digit Codes (All Ford)
Differences in test mode noted as:
(O) = Key On Engine Off test
(R) = Key On Engine Running test
(M) = Memory code
111 System checks OK
112 (O,M) Intake Air Temperature (IAT) sensor is/was low or grounded - IAT
113 (O,M) IAT sensor is/was high or open - IAT
114 (O,R) IAT sensor out of range - IAT
116 (O,R) Engine Coolant (ECT) sensor out of range - ECT
117 (O,M) ECT sensor is/was low or grounded - ECT
118 (O,M) ECT sensor is/was high or open - ECT
121 (O,R,M) Throttle Position (TP) sensor out of range - TPS
122 (O,M) TP low (possibly grounded or open circuit) - TPS
123 (O,M) TP is/was high or short to power - TPS
124 (M) TP voltage was higher than expected - Fuel control
125 (M) TP voltage was lower than expected - Fuel control
126 (O,R,M) MAP or BARO sensor out of range - ">MAP
128 (M) MAP vacuum has not been changing - check vacuum lines - ">MAP
129 (R) No MAP or Mass Air Flow sensor change during "goose" test - MAP MAF
136 (R) Oxygen sensor not switching/system lean Left or Front HO2S - Fuel control
137 (R) Oxygen sensor not switching/system rich Left or Front HO2S - Fuel control
138 (R) Fault in Cold Start Injector circuit - Fuel control
139 (M) Oxygen sensor not switching Left or Front HO2S - Fuel control
144 (M) Oxygen sensor not switching Single, Right or Rear HO2S - Fuel control
157 (R,M) Mass Air Flow signal is/was low or grounded - MAF
158 (O,R,M) MAF sensor is/was high or short to power - MAF
159 (O,R) MAF sensor is/was out of range - MAF
167 (R) No Throttle Position sensor change in "goose" test (must get at least 25% rotation) - TPS
171 (M) Oxygen sensor not switching - system was at adaptive limits - Single, Right or Rear HO2S - Fuel control
172 (R,M) Oxygen sensor not switching - system is or was lean - Single, Right or Rear HO2S - Fuel control
173 (R,M) Oxygen sensor not switching - system is or was rich - Single, Right or Rear HO2S - Fuel control
174 (M) Oxygen sensor was slow in switching Single, Right or Rear HO2S - Fuel control
175 (M) Oxygen sensor not switching - system was at adaptive limits - Left or Front HO2S - Fuel control
176 (M) Oxygen sensor not switching - system is or was lean Left or Front HO2S - Fuel control
177 (M) Oxygen sensor not switching - system was rich Left or Front HO2S - Fuel control
178 (M) Oxygen sensor was slow in switching Left or Front HO2S - Fuel control
179 (M) Fuel system was rich at part throttle Single, Right or Rear HO2S - Fuel control
181 (M) Fuel system was lean at part throttle Single, Right or Rear HO2S - Fuel control
182 (M) Fuel system was rich at idle Single, Right or Rear HO2S - Fuel control
183 (M) Fuel system was lean at idle Single, Right or Rear HO2S - Fuel control
184 (M) Mass Air (MAF) output higher than expected - Fuel control
185 (M) Mass Air (MAF) output lower than expected - Fuel control
186 (M) Injector pulse width longer than expected or Mass Air Flow (MAF) lower than expected - Fuel control
187 Injector pulse width shorter than expected or Mass Air Flow (MAF) higher than expected - Fuel control
188 (M) Fuel system was rich at part throttle - Left or Front HO2S - Fuel control
189 (M) Fuel system was lean at part throttle - Left or Front HO2S - Fuel control
191 (M) Fuel system was rich at idle - Left or Front HO2S - Fuel control
192 (M) Fuel system was lean at idle - Left or Front HO2S - Fuel control
193 Failure in Flexible Fuel (FF) sensor circuit - Fuel control
194 (M) Perform cylinder balance test to check for inoperative injectors
195 (M) Perform cylinder balance test to check for inoperative injectors
211 (M) Ignition PIP signal was erratic or missing - Ignition Systems
212 (M) Ignition TACH signal was erratic (module/wiring) or SPOUT circuit fault - Ignition Systems
213 (R) Ignition SPOUT or SAW circuit open or shorted - Ignition Systems
214 (M) Error in Cylinder ID (CID) circuit or signal - Ignition Systems
215 (M) Primary circuit failure - ignition coil 1 - Ignition Systems
216 (M) Primary circuit failure - ignition coil 2 - Ignition Systems
217 (M) Primary circuit failure - ignition coil 3 - Ignition Systems
218 (M) IDM signal open or high or left coil pack failure - Ignition Systems
219 (M) SPOUT circuit failure, timing defaulted to 10 degrees - follow code 213 diagnosis
222 (M) IDM open or high or right coil pack failure - Ignition Systems
223 (M) Dual Plug (DPI), SPOUT or IDM circuit fault - Ignition Systems
224 (M) Failure in ignition coil primary circuit - Ignition Systems
225 (R) Knock sensor not tested (ignore if not pinging) - KS
226 (O) Ignition Diagnostic Monitor (IDM) signal fault - Ignition Systems
232 (M) EI primary coil circuit failure - Ignition Systems
238 (M) EI primary circuit failure - ignition coil 4 - Ignition Systems
311 (R) AIR system not working - Single, Right or Rear HO2S - Air Injection
312 (R) AIR not diverting - Air Injection
313 (R) AIR not bypassing - Air Injection
314 (R) AIR inoperative, Left or Front HO2S - Air Injection
326 (R,M) Pressure Feedback EGR shows low pressure EGR not seating or not seating intermittantly - PFE
327 (O,R,M) EGR feedback signal is/was low - EVR or PFE
328 (O,R,M) EGR Valve Position (EVP) is/was low - EVR
332 (R,M) EGR did not open/respond during test or if memory code, did not open intermittantly - EVR or PFE
334 (O,R,M) EVP sensor is/was high - EVR
335 (O) EGR feedback signal is/was out of range - EVR or PFE
336 (O,R,M) PFE sensor signal is/was was high - ">PFE
337 (O,R,M) EGR feedback signal is/was was high - EVR
338 (M) Cooling system did not heat up (check cooling system / thermostat operation)
339 (M) Cooling system overheated (check cooling system / thermostat operation)
341 (O) Octane jumper installed (information only code to notify you if it is installed)
411 (R) Idle speed system not controlling idle properly (generally idle too high) - ISC
412 (R) Idle speed system not controlling idle properly (generally idle too low) - ISC
452 (M) Vehicle Speed Sensor (VSS) problem
511 (O) No power to PCM pin 1 or bad PCM (processor)
512 (M) Memory power (PCM pin 1) was interrupted - Was battery disconnected ?
513 (O) Replace processor (PCM) (internal failure)
519 (O) PSP switch/circuit open - PSP
521 (R) Wheel not turned during test or PSP problem - PSP
522 (O) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault - PNP
transmission MLP sensor out of range in park - Transmissions
524 Problem in low speed fuel pump circuit - Power / Fuel Pump Circuits
525 (O,M) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault - PNP
528 (M) System shows voltage at pin 10 (is A/C on ?) or pin 30 (PNP, CPP switch) - PNP
529 (M) Data Communications Link to processor failure
Service any EEC codes, erase memory and retest. If code is still present refer to instrument cluster diagnosis manual.
533 (M) Data Communications Link to instrument cluster failure - see 529
536 (O,R,M) Brake On Off open or shorted to ground - BOO
538 (R) System did not receive "goose" test - TESTS
539 (O) System shows voltage at PCM pin 10. Is A/C on ?
542 (O,M) Fuel pump open, bad ground or always on - - Power / Fuel Pump Circuits
543 (O) Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits
(M) (Service 556 code first if present) Fuel pump relay or battery power feed was open - Power / Fuel Pump Circuits
551 Problem in Intake Manifold Runner Control (IMRC) solenoid/circuit - Solenoids
552 (O) AIRB solenoid/circuit failure - Solenoids
553 (O) AIRD solenoid/circuit failure - Solenoids
554 (O) Fuel Press Regulator Control solenoid/circuit fault - Power / Fuel Pump Circuits
556 (O,M) Fuel pump relay primary circuit fault - Power / Fuel Pump Circuits
557 (O,M) Low speed pump relay primary circuit fault - Power / Fuel Pump Circuits
558 (O) EGR vacuum regulator solenoid/circuit failure - EVR or PFE or Solenoids
559 (O) A/C relay primary circuit fault - A/C and Fan Circuits
563 (O) High Fan Control (HFC) circuit failure - A/C and Fan Circuits
564 (O) Fan Control (FC) circuit failure - A/C and Fan Circuits
565 (O) Canister Purge 1 solenoid/circuit failure - Solenoids
566 (O) transmission 3/4 shift solenoid/circuit - Transmissions
569 (O) Canister Purge 2 solenoid/circuit failure - Solenoids
578 (M) A/C pressure sensor VREF short to ground - A/C and Fan Circuits
579 (M) ACP sensor did not change with A/C on - A/C and Fan Circuits
581 (M) Cooling fan current was excessive - A/C and Fan Circuits
582 (O) Open cooling fan circuit - A/C and Fan Circuits
583 (M) Fuel pump current was excessive - Power / Fuel Pump Circuits
584 (M) Open power ground circuit - Power / Fuel Pump Circuits
585 (M) A/C clutch current was excessive - A/C and Fan Circuits
586 (M) Open circuit in A/C clutch - A/C and Fan Circuits
587 (O, M) Communication problem between PCM and Variable Control Relay Module (VCRM) - Power / Fuel Pump Circuits
617 (M) Transmission shift failure (1/2 shift) - Transmissions
618 (M) Transmission shift failure (2/3 shift) - Transmissions
619 (M) Transmission shift failure (3/4 shift) - Transmissions
621 (O) Solenoid/circuit failure - shift solenoid 1 - Transmissions
622 (O) Solenoid/circuit failure - shift solenoid 2 - Transmissions
624 (O,M) Solenoid/circuit failure -Electronic Pressure Control (EPC) current is high - Transmissions
625 (O,M) Solenoid/circuit failure - Electronic Pressure Control (EPC) current is low - Transmissions
626 (O) Transmission Coast Clutch (CCS) Solenoid/circuit fault - Transmissions
627 (O) Torque Converter Clutch circuit fault - Transmissions
628 (M) Excessive converter clutch slippage - Transmissions
629 (O,M) Torque Converter Clutch circuit fault - Transmissions
631 (O) Overdrive Cancel Light circuit problem - Transmissions
632 (R) E4OD - Transmission Control Switch (TCS) should be cycled once between engine ID and Goose test
633 (O) 4x4L switch should be in 4x2 or 4x4 high for the test
634 (O,M) Park/Neutral Position (PNP) or Clutch Pedal Position (CPP) circuit fault
Electronic shift transmission - Manual Lever Position (MLP) sensor out of range in PARK - Transmissions
636 (O,R) Transmission Oil Temperature (TOT) sensor out of range - Transmissions
637 (O,M) TOT sensor is/was high or open - Transmissions
638 (O,M) TOT sensor is/was low or grounded - Transmissions
639 (R,M) Transmission Speed sensor (TSS) circuit fault - Transmissions
641 (O) Transmission solenoid/circuit failure Shift Solenoid 3 - Transmissions
643 (O)(M) Torque Converter Clutch (TCC) circuit - Transmissions
645 (M) Transmission 1st gear failure - Transmissions
646 (M) Transmission 2nd gear failure - Transmissions
647 (M) Transmission 3rd gear failure - Transmissions
648 (M) Transmission 4th gear failure - Transmissions
649 (M) Transmission EPC system failure - Transmissions
651 (M) Transmission EPC solenoid/circuit fault - Transmissions
652 (O) Torque Converter Clutch (TCC) circuit fault - Transmissions
654 (O) Transmission selector not in PARK - Transmissions
656 (M) Torque Converter Clutch (TCC) slip - Transmissions
657 (M) Transmission temperature was excessive - Transmissions
998 (R) Did not pass Key On Engine Off test yet (Get 111 in KOEO first)
(O) Transmission Electronic Pressure Control (EPC) solenoid/circuit fault - Transmissions
Definitions:
ACT - Air Charge Temperature Sensor
BP - See MAP
EEC - Electronic Engine Control System
ECT - Engine Coolant Temperature Sensor
EGR - Exhaust Gas Recirculation Valve
EVP - EGR Valve Position Sensor
HEGO - Heated Exhaust Gas Oxygen Sensor
KOEO - Key On Engine Off
KOER - Key On Engine Running
MAF - Mass Air Flow Sensor
MAP - Manifold Absolute Pressure Sensor
MLP - Manual Lever Position
PCM - Powertrain Control Module
SPOUT - Distributor Jumper to Allow Initial Timing
TP - Throttle Position Sensor
#1336301 07/16/05 02:30 AM
dk616 Offline OP
Wow! Thanks a lot. Is that something Autozone can read if I threw a code? I really think it's the guage, I've never seen a car heat up so fast. Within 1/4 mile it's to the "o" from a cold start! But she did say she smelled something "sweet" in the cabin tonight (UH-OH)
#1336302 07/16/05 07:32 AM
No, you need to do the paper clip thing or get an OBD-1 scanner from the auto store or Wal-Mart.
Although a blown head gasket can heat up quick, the temp sender may just be bad. The usuall is to pull the plugs and inspect for coolant or clean cylinders. If you find nothing you can either take the car's temperature (haha) or unscrew the sender and stick it in a cup of boiling water while reading the gage.
Temp sender
Paper clip method
#1336303 07/16/05 09:20 AM
dk616 Offline OP
Thanks- There ain't no way I'm pullin that Temp Sender again. The cuts on my wrist and hands haven't healed up from installing the new one! I think I'll try the paperclip method or just buy another OBD-1 Scanner (I had one for an 89 astro I had)
I didn't know that a blown head gasket could cause it to heat up quickly. The plugs all look clean with no single one being a different color but maybe it's time to run a compression check or have the system pressure tested. I'm just tryn to avoid takin it to a stealership and I don't have a mechanic that I trust also, my daughter SHOULD be paying for the repairs (not that I've made her) Thanks for all your help. you have no idea how much it's appreciated! I've never tackled a Head Gasket, but I'm willin to give it a shot!
#1336304 07/16/05 02:43 PM
This is a simple check also for overheating. This just happened to me and we couldnt figure out what was causing it because thermostat was fine and so was coolant when we put the dye in it. We removed the radiator and sprayed the hell out of it with the house. SO MANY bugs and stuff came out. Drove it around and now its at "R" all the time. Doesnt move much really!
96 Contour Clarion VRX935VD My Car
#1336305 07/16/05 04:56 PM
My car was doing the same thing until I put the splash sheild back on(the black peice that goes under the radiator).That peice circulates the flow of air around the radiator.With the sheild back on my fans come on alot more. Do you have that on her car? If not put it back on and check it out. Once I put that back my temp was outstanding.
2006 Mustang GT 2004 Mustang GT (Gone) 2004 Yamaha FZ1 1995 Contour GL 1982 Cutlass 2 door
#1336306 07/16/05 06:35 PM
dk616 Offline OP
I've been lurking around here for 3 or four weeks and read all the posts about overheating! I've got the lower shroud on it. I had to drop it down to install the resistor, but I was sure to re-install it. I guess I should try removing the Rad. and spraying it, it's just that I know it's been driven hot and everything I read say's the Zetec's will blow a head gasket for sure! And it heats up so damn fast that I have a baaaaad feeling! Where did you get the dye? is it something I can buy or does a shop have to do it? Thanks again for all the help, I sure need it!
Page 1 of 3 1 2 3
