Posts: 392 |
Hey guys. Just finished installing my rear struts and springs couple minutes ago. I was curious to how you guys adjust the rear? Its kinda hard to get the knob into the hole. Is there something im missing?
2005 Nissan Sentra Spec V
Posts: 4,140 |
Originally posted by BigT: Its kinda hard to get the knob into the hole.
"Wrong hole, you're putting it in the wrong hole!"
Sorry, I couldn't help myself... Are you making sure it lines up properly? You didn't mangle anything in the install, did you? Maybe new it's a little snug, but I've never seen one that was tough to get in. Take a good look at the interface and carefully line it up.
Posts: 759 |
Im about to do my Konis as well. From what I have searched, you have to grind down the knob for the rears so it will actually fit, just the area you grab, not the actual adjuster.
E0 #4384 of 6535
Born Jan. 9 1998
My SVT from the ashes
147,466 miles, purchased Nov. 2002 @ 76,559 miles
Posts: 392 |
Sounds good
Posts: 3,867 |
Originally posted by CSVT985: Im about to do my Konis as well. From what I have searched, you have to grind down the knob for the rears so it will actually fit, just the area you grab, not the actual adjuster.
That's a common fix, but I found I didn't have to do that. I peeled back the carpet in that little corner, and removed any white foam sticky-tape/padding from around the hole, and I had just enough clearance.
Function before fashion.
'96 Contour SE
Posts: 5,975 |
Originally posted by RogerB: Originally posted by CSVT985: Im about to do my Konis as well. From what I have searched, you have to grind down the knob for the rears so it will actually fit, just the area you grab, not the actual adjuster.
As did I.
Posts: 4,760 |
Originally posted by SVT PETE: Originally posted by RogerB: Originally posted by CSVT985: Im about to do my Konis as well. From what I have searched, you have to grind down the knob for the rears so it will actually fit, just the area you grab, not the actual adjuster.
As did I.
Bingo
Team Evo
Staz: You know why they call it Skunkworks?
Everyone: Why?
Staz: Because everything that comes out of it stinks!!!
Steeda-I hate you stazi
Posts: 41 |
I just installed mine last weekend. I had to cut the knob to fit the rear.
I don't know if you've road tested yet....but the Koni's kick serious ass. I have this long winding curve that I drive every night on my way home. With the stock suspension my car would start to get uncomfortable around 100mph....with the Koni's I get up to 120mph and still feel comfortable. I have the Koni Sport Kit, and it provides the perfect ride height and wheel clearence for my 18's.
I'm gonna post some pics of my car tonight when I get home.
"They say geniuses pick green"
2000 CSVT- Tropic Green #1261 of 2150
3A Performance exhaust
Kurtz cold air kit
18" Tuner 15 spoke
Koni Sport Kit
