Posts: 183 |
I recently in the past 4 month got my brakes replaced, and new front rotors. When I do a semi agressive turn, like maybe doing 20mph through a 90 degree turn I can hear a squealing comming from the left front wheel. It seems to happen once the wheel gets to about 75 degrees from straight. I was wondering what it could be. the power steering fluid is full so I dont think it is that.
Posts: 148 |
i had the same prob with mine about 3 months ago it was the power steering only prob was it needed the air bleed out of it . try this start the car raise the hood remove the power steering pump lid get in the car and turn the wheel all the way from left to right about 6 or 7 time this fixed mine good luck.let me know if it works.
Posts: 6,910 |
in this case are you holding the wheel against the stop? if so don't and you will not hear any noises and your pump will last longer
- 95 Mystique LS - Zetec/5spd
Posts: 183 |
No my wheel is not against the stop, its not even sideways. I noticed today that the car was squealing when I was going in a straight line, well a slight turn maybe 3 degrees, so i dont know what it is :-/
Posts: 1,456 |
Does it do it with the engine just idling? If so, take a listen under the hood.
Posts: 183 |
no it does not make that noise while sitting still, only while under way, reving the engine does not re create the sound either. I notice it when I am doing right hand turns. Myabe ill get a friend to video tape it
Posts: 7,100 |
maybe I missed it, but did anyone ask about the power steering fluid level? low fluid will groan (generally not described as a squeal)
Have you looked at how much freeplay you have on the serp. belt? under load you may be slipping, though at a stop and revving it, should still spin quietly.
Ray
'99 CSVT - Silver #222/276
Posts: 183 |
The power steering level is full. I will check the belt, I remeber my mechanic saying that the belt could be replaced in the next half yr.
Posts: 1,017 |
you must've already checked, but your tires are fully inflated right?
1995 SE
2.5L V6/MTX
187k
Posts: 183 |
yeah, even though I hate those tires, the squeal so much, makes me look like an idiot, maybe the parents put them on there so I will slow down...
Well i talked to my mechanic today, he is going to get me a new belt, its only 30$ or so, so that'll be worth it, he is also going to look at my A/C since it is starting to not blow cold, just mildly cool.
