Posts: 499 |
I installed the SS brake lines from BAT this w/n and I'm not sure the hard line is seated correctly into the new lines. I can see about 1 or 2 threads remaining on the hard line connector, is this normal?
1999 Contour SVT #1966/2760, Silver Frost/Midnight Blue
Koni Kit, Mille Miglia MM-S rims, B&M shifter, Stazi mesh, SFCs, optimized Y-pipe & TB, SS break lines, K&N drop-in, Infinity Kappa speakers, MTX amp/sub
Posts: 6,700 |
*runs outside and looks at mine* I have about 1.25-1.5 threads exposed. I think you are alright.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 4,140 |
If it torques tight, I wouldn't worry.I'd actually be more worried if they went in all the way, since they seal inside.
Posts: 499 |
Thanks for the reply! I haven't noticed any pretty blue brake fluid on my garage floor, so they must be sealed properly. Just wanted to double check.
Posts: 650 |
Heh, how long were they delayed for you? I just installed mine and there are a couple of threads exposed, but no apparent leaks. I just have to get a thicker clip for the frame bracket, then I think I'll be set!
97 Zetec MTX Sport
Mk1 Mondeo Morettes & Clear corners
Full SVT kit w/ Molded Mirko Splitter, Carbon Fibre Hood
Ground Control coilovers w/ Koni adjustables, BAT anti roll bar
Pics of my rides in my profile!
Rally drivers do it sideways......
Posts: 499 |
Delay? In terms of shipping or what?
Posts: 650 |
oh, nothing really, mine were held up for a bit because of a part needed for the kit..
97 Zetec MTX Sport
Posts: 499 |
Yeah, my rear lines were back-ordered w/ BAT for about 3 weeks waiting for the strut bushing to be fabbed. I received them the other day and will hopefully install them this w/n!
On a side note, when I install the rear lines, do I need to bleed the entire system again or will bleeding the new rear lines be sufficient?
Posts: 4,693 |
You only need to bleed the wheels where the lines are installed unless you end up somehow running the master cylinder dry.
If you have not changed the brake fluid recently, this would be a good time, but it sounds like you have already done that.
Jim Johnson
98 SVT
03 Escape Limited
