Posts: 101 |
Hey yall
its been a while i have a few questions.
Ummm ok does my 1995 mystique 2.5l V6 have a return or returnless fuel system. Contemplating ZEX nitrous kit!
What is the reason for NOT running splitfire or other Similar type plugs in nitrous bearing 2.5L's.
I wanna go DRY to save money but don't want to blow the 2.5 till i have my 3.0 built will she survive a whole 50 hp shot?
Where is a good shop in Southern Ontario (Toronto, Ottawa) that knows our cars, PERFORMANCE WISE?
Hypothetical question!
1.If an Nissan Pulsar NX 2000 is running a 75 shot can i beat him in a HEADS UP DIG race? Running the 50 shot.
2.I haven't looked at the exhaust manifolds up close yet but are they cast-steel? and if it were possible could something be fabricated from them to run a BASTARD Twin turbo system? and if yes would a couple of t25's fit under there somehow? lastly is there a double inlet to single outlet intercooler in existence?
I haven't updated my sig but i have done some more mods. i did get a set of 24 lb/hr injectors, UIM/LIM, Different short ram, Custom 2.5 inch stainless Exhaust to magnaflow 3 inch sans resonator, and a set of SVT cams. It's more like an SVT. Oh ya im at 77,251 KMS now
sorry for the novel.
any answer or quirp is acceptable
1995 Mystique, 2.5 V6, MTX, 2.5 inch Exhaust tubing, Vibrant Highflow CAT, Vibrant 2.5 Resonator, Magnaflow Muffler, SVT cams, Ebay Intake *YAWN*, HELLA 550's. FINAL LAP Is my New Best Friend!
Posts: 6,106 |
You have a return fuel system.
Don't worry about the reasons why NOT to run split fire or Bosch +4 plugs, just DON'T!! If you're going to be running nitrous, you'll need a copper plug(NGK TR-55). You should be fine with stock heat range with a 50 shot.
The 2.5L "should" handle the 50 shot like nothing, as long as your car has been maintained well.
You're on your own on finding a shop in Canada.
1: WTF is a Nissan Pulsar NX? If I'm thinking correctly, they are one of those little hatchback 4cylinders? My guess is that you should take him.
2: Please do a little more searching. You will find that a twin-turbo setup is NOT the way to go, nor is it really that feasable without a TON of money. There is no benefit to a twin turbo over a single.
Your car definitely won't run correctly with the 24# injectors, without a chip/tune. I would STRONGLY advise having the car tuned, or calling either ADC or Hypnotic Illussions Automotive for a chip/SCT X-Cal programmer.
Mark
2000 Black CSVT
Posts: 101 |
well its a good thing i havent intalled those injectors yet i woulda been realy dissapointing to put them in and not have them work.
ya nx 2000 pulsars are after the boxy model but use nissans sr20de motor, so you have a 2200 lb car with decent power.
ok then
Posts: 6,106 |
Depending on the style of injector, they may "work". You will see a rich condition though. This is why I suggested you pay the extra $300-$450 to get a chip that ties everything together.
Mark
2000 Black CSVT
