98 Contour GL 2.0L ATX
Upgrading to BAT 21MM rear swaybar problem.
First I started with my Contour.
Safely got it off the ground.
Removed old sway bar
Started installing new say bar, problem. The bracket won't push back up into place (Even with sway links disconnected) so I came up with this idea. Which wasn't good I'll get into that after.
Now jacking it up did get it into place. I drove it and it seemed fine and very happy with the feel) It still seems fine but doesn't sound it.
First noise I figured out, was because I didn't grease the inside of the bushings. It was the worst of the 2 noise. So remember grease those I.D holes of your new bushings.
The second noise is the click clack that I get on my road. It's being caused by the fact that the bracket is getting bent on the side that slides/hooks into sub frame. I checked with ford dealer and they said only one size was made for all contour models (they could be wrong I'm sure) but seems either I have to cut some of the bushing back about an 1/8th where it mates with the sub frame (which can't be done because the stopper on the swaybar will hit the sub frame I'm sure) or find a deeper U-bend brackets. Maybe find someone to fab some for me
What I did find on here, was talk of welding brackets but that will mean removing the sub frame. Which I want to stay away from. I only do street so not looking to go in to that kinda work.
I though I saw brackets at one time, but can't remember.
JD
