Posts: 498 |
Lance Kinley wrote: [Quoting jjh]How do I get this info? There are two different ways...
There's a sticker in the passenger side door jam, at the front near the door-open sensor. Where? I don't see any sticker here. OR, you can look at the sticker on the PCM port cover under the glove box. Just peek under the glove box in the footwell.  I don't see one here either.
{I do hate spam, but that isn't really part of my email address. Remove the string ?HatesSpam? from the email address ?BobHatesSpam@blaylock.to? to email me. No advertisements. Spammers will be dealt with very harshly!} ------- Moonlight Blue 1996 Mercury Mystique GS , Zetec engine, ATX. No mods. (Well, OK, one mod. Before I got rid of my previous car, a 1994 Tempo, I swapped radios. I liked the Tempo's radio better. That counts as a mod, doesn't it? I also kept one of my Tempo's wheels to use as a spare. I hate those stupid ?compact? spares that come with modern cars. Does this count as a mod? If so, I guess I have two mods. Replaced burned/melted blower switch and connector on 19 February 2002 with a 1P3T toggle switch from Marvac and a Molex connector from Rat Shack; I guess this now makes three mods.)
Posts: 9,178 |
Originally posted by Bob Blaylock: OR, you can look at the sticker on the PCM port cover under the glove box. Just peek under the glove box in the footwell.
I don't see one here either.Look under the brace that holds the computer up.
Posts: 2,523 |
Yep, it should be under that brace. Mine was and I had to bend it around to read it.
125.2 FWHP - 126.5 FWTQ SVT exhaust (#4 of 9) - B&M FPR - Custom CAI - bnoon optimized TB #1 & 2 (beat that!!) Black '98.5 SE Zetec MTX Best quote seen in a chat - "Jinx 12345678910 you owe me a naked picture of yourself!"
Posts: 761 |
Originally posted by D Davis: Yep, it should be under that brace. Mine was and I had to bend it around to read it. Me too, pain in the hiney ALZ3 98 Mystique GS Zetec ATX, mfg 6/97
Posts: 352 |
2000 Silver Frost SVT #1625 14 Jan 2000 Dual Mode Dampener A/C switched K&N Dropin Magnecor
Posts: 164 |
After standing on my head to see the PCM, there is a white sticker with 4 letters on it along with what might be part of the VIN. I'm assuming that my info is:
1996, NPEF, Ztech, GS
- Jim
'96 Mystique GS, Ztech - ATX, with CD changer, Sylvania Cool Blues, sunroof, keyless entry, and 9mm blue wires
Posts: 7,329 |
2000 SVT Contour #674 12/02/99 Code: XGT1
Posts: 3,419 |
Originally posted by JWard: After standing on my head to see the PCM, there is a white sticker with 4 letters on it along with what might be part of the VIN. I'm assuming that my info is:
1996, NPEF, Ztech, GS NPEF is the plant that made it - not the code (NPEF = "North Penn Electronics Facility"). My paychecks said that many moons ago. The code you want will be letter-letter-letter-number. It is on the connector up top if you feel like removing the entire PCM.
Posts: 1,692 |
Originally posted by Lance Kinley: Originally posted by jjh: [b]How do I get this info? There are two different ways...
There's a sticker in the passenger side door jam, at the front near the door-open sensor. OR, you can look at the sticker on the PCM port cover under the glove box. Just peek under the glove box in the footwell.
-Lance[/b]or you look under the hood at the sticker ford put on it when they updated the code and have chris tell me what it translated to which was: AAB6--- use to be AAB5 ( according to the computers sticker) 96 GL Zetec
Joe Hartley "yes I know it's a MTX Zetec but it beats having a ATX Duratec" Champagne 96 GL MTX some mods dynoed at 114.2whp and 124.4wtq (pre CTA intake) 16.858 @ 80.76mph (yes it's slow but still faster than D Davis) AIM: ZetecRacing My Site My Profile
Posts: 153 |
GPL1
97 SE built 9/96
I have the distinction of having a weird code that there is no chip for, probably due to the fact 97 was a short year, and 97 SE's with MTX and CA/NY emissions (assuming that makes a difference to the code???)were probably the rarest of that year.
97 SE MTX, KKM, UR UDP, 19# Injectors, SVT TB, SVT UIM, SVT Flywheel, Grizzly Street Clutch, Upgraded motor mounts, mystifed precats, brand new main cat, SVT exhaust sans resonator, 205-55-15 Dunlop SP5000's 154hp / 156 tq before the SVT exhaust, SVT dual honed upper and swapping the mystery main cat for mystery precats. My Profile
