While out on vacation to the east coast of Canada to visit my family, I decided it was time to bring some life back into my sisters Mystique's headlights (And to test this on her car first ). I did this at the end of a lot of driving as evidenced by the amount of bugs on the front of the vehicle. Figured I would share the process as many Contiques suffer from this syndrome:
Before:
Before driver's side:
After passengers side
Halfway both:
The lights look just like new - pictures do not do it justice. Unfortunately, I did not get a chance to get a picture after I was done both of them and washing the car.
Pretty simple process that I have been using for years to do the dashes and plastic lens' on classic cars:
Step 1: Clean the lights
Step 2: Mask around the lights with masking tape
Step 3: Start off with 1000 grit wet/dry sandpaper (yes.. sandpaper). Wet down the lights before you begin. Sand away using inline motions across the light. Have a garden hose handy to keep the surface wet, and to wash away the water that builds up with dirt etc from the lights. Always make sure the surface is is wet. You may have to use 400/600 grit if there is excessive discoloration and pitting.
Step 4: Follow up with 1500 grit paper until most of the scratches etc are gone, as well as the yellow haze that has built up over the years.
Step 5: Dry off the lights - Grab a "beverage of choice" before you look at them. The lights will look horrible after the previous step. You will barely be able to see the actual bulbs etc.
You may have to re-apply masking tape.
Step 6 (Optional): Use Meguiars's metal polish to bring the lights back to life once again. This polish is more aggressive than the stuff in the nest step, so it saves a bit of time. Use firm circular motions - This requires lots of elbow grease. Once you are satisfied, polish with a clean cloth.
Step 6: Apply 3M plastic polish to the lights, and apply similar to the last step. Keep applying until satisfied with the finish (Assuming the lights are not too far gone). Use dry clean cloths to polish to a brilliant shine .
Step 6: Grab another "beverage of choice" - you earned it.
Materials:
-Making Tape
-Package of assorted wet/dry sandpaper (400/600/1000/1500 grits). May have to buy separately.
-Source of clean water - bucket, hose etc.
-Meguiars metal polish
-3M Plastic Polish (Meguiars plastic polish should work as well).
-Bag of polishing cloths
-"Beverage of choice" - several required
-Friend (to do the other light at the same time)
Looks good!
N
N
Looks good.
Where in New Brunswick were U?
Most of my time was spent in Fredericton, but I was in Moncton and Alma (Fundy National Park) for a few days also. I was all over the east coast for a week or so (NB, NS, PEI).
E
E
hmmm........ TO AUTOZONE!!!! crap, it's closed right now(4 in the morning)
tomorrow then
that looks amazing, I'm definitely hitting up autozone tomorrow
98-98.5 Silver Contour SVT short shifter Panasonic HU 2 12" MTX 8000's MA Audio mono block amp homemade box
I followed these simple steps about two weeks ago. I couldn't see the headlight bulb through the lens they were so bad. It worked out great! I didn't even spend a bunch of time polishing them. Most of the people I showed them too thought I bought new ones.
I was scared to death to sand them but I figured I had nothing to lose. If you haven't done it, try it! You will be happy you did when you are done.
98 Ford Contour SVT - No mods 02 Suzuki GSXR 750 - No mods needed lol
awesome job, i might have a try with mine
1998 Ford Contour Se 2.5 litre Silver frost
Its alot easier to do if you take them off the car first. That way you don't have to mask anything off and you don't have to operate on them at a weird angle.
Cameron 98 Black CSVT #2958
You made a great improvement on those headlights. Mine are so bad that there is no repairing them, so I just bought new ones.
Justin 1999 Ford SVT Contour (T-Red) Cardomain site
looks great! i did that to one of my lights and am going to do the other but cant find time...
your steps are surprisingly similar to the FAQ
