Posts: 157 |
Originally posted by MxRacerCam: Originally posted by GoldnTour: But for Bass its a different story. since bass can be locked down to only several low frequecies, when there is distortion or the signal is not purfect you will hear it.
i guess its why most mids and highs are oval because it does not matter that much SQ is affected but not by much. if you buy really high end mid/high speeakers they will probably be round. they reproduce evenly all around the cone
and subs are round.
ruh-roh! stillwater and xtant had better stop making those funny looking woofers then!!
Originally posted by GoldnTour: i be wrong
edited for accuracy.
ok then ill shut up now
~Crystian
2000 Se sport
2001 Lightning(Sorry!your mom cant come with us)
Posts: 1,317 |
thank you to those who told me how to fit what i planned instead of suggesting something that i never intended to use in the first place.
anyways, i went to go buy pioneer 6x9's tonight but they were sold out. theyre getting them back in on friday and i will probably install them this weekend.
~Ryan
1999 T-Red SVT Contour
41k Miles #1701 / 2760
B&M, Custom Y-Pipe, Alpine HU, Pioneer 6x8's & 6x9's
I feel Guilty, Oh so guilty
Posts: 4,789 |
I apologize for offering a better, cheaper alternative.
-Mitch Hedberg
Posts: 1,317 |
i dont want to have to make mounting brackets for components or have to run extra wires for the crossover. 6x9's are better than my original 6x8's that i was going to use and are more than sufficient for my application
~Ryan
Posts: 4,789 |
Originally posted by guitarman19853: i dont want to have to make mounting brackets for components or have to run extra wires for the crossover. 6x9's are better than my original 6x8's that i was going to use and are more than sufficient for my application
Sorry, I didn't notice you specifying that anywhere. I just saw you mention that oval speakers were cheaper, so I gave you a better sounding, less expensive model. If minimal work was more important than price or quality, i would have recommended some coax drivers.
-Mitch Hedberg
Posts: 2,978 |
dnew, I am still in the process of figuring out what I want do to for fronts. I was looking at what you suggested and I had 2 quick questions. 1 - I notice the larger speaker is 7", i am pretty sure it will, but it will put out much more bass then the 5.25 components currently. 2 - how hard is it to build a crossover, I have never done it before. Thanks!
I am just trying to build a really decent sounding system now.
Posts: 2,163 |
guitarman19853
chose one of these low profile 6X9s
Boston's premier high performance 2-way car coaxial speakers SL95 6 x 9" $300.00 / pair (USA) Nominal Size 60watts RMS-200 watts peak 4 ohm 35Hz-20kHz Sensitivity [1 watt (2.83v) at 1m] 92dB Mounting Depth 2-5/8" (67.0mm)
Blaupunkt Overdrive Series 6x9" 3-way Coaxial speaker ODx693 Suggested Retail Price.....$219.95 Mounting Depth flush2.24 mm
Directed SX Coaxial Speaker SX690 6" x 9" Magnet, neo 40.5 g, neo Power Handling 40 60 watts RMS/120 peak Impedance 4 ohm Freq. Resp. 50Hz - 21kHz Efficiency 89 dB 90 dB @ 1 watt/1 meter Tweeter Description 25mm treated silk dome Depth 2 1/2" Grills Yes
Posts: 4,789 |
Originally posted by Digital Slacker: dnew, I am still in the process of figuring out what I want do to for fronts. I was looking at what you suggested and I had 2 quick questions. 1 - I notice the larger speaker is 7", i am pretty sure it will, but it will put out much more bass then the 5.25 components currently. 2 - how hard is it to build a crossover, I have never done it before. Thanks!
I use that midbass in my ranger, and I couldnt' be happier for the price paid. Strong midbass presence that seems to defy its 2mm xmax. They easily outperform my 6.5" mb quart mids from my contour on the low end. At the top end, they aren't quite as detailed, but again, for the price they are good. My only beef with them is the frame is kind of thin metal compared to higher quality drivers. If you have a soldering iron, crossovers couldn't be easier.
-Mitch Hedberg
Posts: 2,978 |
I may end up purchasing them later this evening and attempting to build a crossover this weekend when i install my amps and sub. You know any good places that show how to build one? Or will google just tell me...
Posts: 4,789 |
Where do you plan on putting the tweeters?
-Mitch Hedberg
