Posts: 1,130 |
I have blown another Koni strut and and dont understand why. This happened once already after hitting a large pothole. I replaced the blown strut a week or two ago, and I have found the same problem with the same strut. The adjustment knob wont turn, and the strut is covered in oil. I haven't hit any potholes or caused any damage to the car. What the hell is going on?? Why has the same strut blown twice?
I am so pissed! I am moving to FL soon, and I wont have any place to work on my car when problems like this occur. I don't think it is an installation issue, because I installed it just like the others, and have had no problem with them.
Originally posted by Who the F are You?: does your family tree not have any branches on it?
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 1,130 |
The only thing I can think of is that the bump stops are cut too short, and allowing the strut to bottom out and damage itself. Both front bump stops are cut to the same size, but only one strut is causing me problems. This problem makes no sense whatsoever.
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 1,130 |
Somebody help me out here. I am going crazy trying to figure why my strut blew in a week in a half.
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 1,578 |
Sorry I can't help, but I'm interested in why that is going on as well so I'll do what I can.
Bump
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
98 'Tour SE 24V 5-spd
149 HP @5900
148 LB FT @4300
Posts: 1,130 |
I just hope Koni can get me a new one before next sunday. I am driving my SVT to Tampa, FL next week.
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 533 |
do you have the KONI 1130 Sport Kit? i was planing on buying it this week and your problem troubles me; not sure what to do.
hope everything goes well and safe trip to FL
-a
koni kit - hpp rstb
camber/plates - cf (yikes!)
polyroll resistors - TCA's
WR headers/ypipe -TB hiflow cat
SFC's - XCal2
-dreaming of 3L-
Posts: 10,015 |
I can only imagine the same thing. either you cut the bump stop too short (or didn't even use one) or the car is way to low.
Somehow you must be allowing the strut to bottom out and get damaged.
Your problem is unique. I've never heard of anyone blowing a strut as quick as you, and a KONI to boot!
Please explain, in detail, your setup.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 1,130 |
I followed the how to and cut the bump stops in half. The problem has happened twice in a row on the front drivers side strut. The struts were installed properly and also have the camber kit with thicker camber plates. Both the drivers and passenger side front struts were installed the same way. Both bump stops were cut exactly the same, and both were on full hard. The driver's side is the only one giving me problems. The strut is covered in oil, the adustment tab wont turn, and it feels like it is riding on just the spring.
99SVT
235hp @ 6550rpm
212tq @ 5350rpm
Posts: 508 |
What springs you using? If there coil overs your too low maybe? Other than that trying going 3/4 bump stop.
JD
JD a.k.a Fingers
"Don't Panic"
'98 Contour GL 2.0L VCT ATX 88k
'98 Contour LX 2.5L MTX 120k
Street racing can kill
just less of a chance with a 2.0
Posts: 4,149 |
Originally posted by jd28: What springs you using? If there coil overs your too low maybe? Other than that trying going 3/4 bump stop.
JD
His signature lists the Koni kit.
-- 1999 SVT #220 --
