Posts: 275 |
Originally posted by GoldnTour: At E.T.L Audio we install the products that are client�s need. As the Electronics' Advance so do we. That�s why we carry all the newest product�s and supplies to make are client�s know we care.
Might want to update the "are client's know we care" to "our clients" just a heads up if the website is new.
not hating or nothing
Yah thats what happens when you design it and a idiot types it up. thats only my first rev, rev two is soon to come
Posts: 7,117 |
Originally posted by eyevancsu: If there is enough space within the imrc a small heatsink coudl be attached to the transistor, but i dont know if there is any space at all. Id still be interested in the relocation kit.
If there is space, it is on the underside of the IMRC with the board on top of it. You won't be very effective trying to get heat out of there I'm afraid.
I just don't get why Ford would put an electronic component like that in a box on top of a valve cover... then cover it with a chunk of heat catching plastic. Plenty of cooler places to put it, & even under the battery or air box it would be out of sight too.
The kit sounds like a good idea for most as it will help to prevent premature failure. An ounce of prevention...
Posts: 2,426 |
Originally posted by TourDeForce: The kit sounds like a good idea for most as it will help to prevent premature failure. An ounce of prevention...
This is exactly why a relocation kit is preferable to trying to desolder and resolder a transistor that you don't have. Preventive maintenance is preferable.
Posts: 1,786 |
You people aren't understanding that the transistor that was originally put in the IMRC was faulty (tolerence issues). The newer TIP121 is a MUCH better replacement if you compare the two spec sheets. Yes, it can handle the underhood temps.
Additionally, relocating the IMRC just delays the heat issue. If your IMRC is failing now due to heat, relocating it might give you 15-30 minutes more of operation before it heats back up and stops working.
If you relocate it, you still have a faulty transistor.
Oh, and in case you are new here, ask around. I know a thing or two about the Contour and its electronics.
-Auto Mak or-
-Experiment or
-Station Wagon or-
-Computeriz or-
I have a foot that is bigger than a foot.
SuperChipFOR SALE
Posts: 297 |
Originally posted by The Chris: If I can get 10+ people to send me $2, I'll buy 20 of them and write a How-To for fixing the damn thing. Then, I will mail one of them to you. It shouldn't take more than 1 hour to fix with a solder iron.
Who's in? Maybe this would be a group buy?
I'm in!
Posts: 7,117 |
Originally posted by The Chris: Originally posted by wa2tuff: Originally posted by TourDeForce: The kit sounds like a good idea for most as it will help to prevent premature failure. An ounce of prevention...
New... hehe.
I understand just fine. My IMRC is NOT faulty, so I will relocate it to prevent premature failure and/or prolong its life. GET IT??
You aren't suggesting people rip open their perfectly fine & functioning IMRC box just to replace this transistor, are you? The time to rip appart the IMRC to replace the thingy is AFTER the failure and BEFORE investing in a replacement IMRC. GET IT?
GOT IT?
GOOD!
Posts: 715 |
Originally posted by DDV: Originally posted by The Chris: If I can get 10+ people to send me $2, I'll buy 20 of them and write a How-To for fixing the damn thing. Then, I will mail one of them to you. It shouldn't take more than 1 hour to fix with a solder iron.
I'm in!
Me too!
Brian W. -------------------- Black 1998 SE 5 speed - TOTALLED
Posts: 1,322 |
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760.
"Many posted questions are answered by farm boys"
Posts: 203 |
I thought this was an imrc relocation kit GB, not a transistor GB? Maybe you should start a new thread about it.
-ivan c.
Posts: 604 |
somebody needs to take there ball and go home, sounds like a god damn playground
