Administrator
Administrator
Posts: 702 |
I want to get an exhaustive list of PCM codes for the site. If you don't see yours listed here, please post! I'll need year, engine code, engine type, and model. So far, here's what I know of:
1995, NUN1, Duratec, GL,SE 1995, NUN3, Duratec, SE
-Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 878 |
"Function before fashion."
'96 Contour SE
Posts: 9,178 |
Posts: 175 |
Midnight Red '95 Contour SE ATX Just completed the lighted moonroof switch mod. Its great! www.webcentrix.org/contour_se.html "The whole purpose of a car is not to go fast it's to get from point A to B, and if you can afford it, to get from point A to B with some sense of style." As seen on the Ricecop.com boards
Posts: 2,025 |
1998 SVT Contour E1, Black 2001 Honda SuperHawk VTR1000F "I bent my Wookie" www.mamisano.com
Posts: 3,248 |
SFG-2, 99SVT built 12/1/98
1999 Amazon Green SVT Contour (#554/2760) Stock SVT Duratec V6 with: Intake- K&N filter/75mm MAF meter Exhaust- MSDS Y-pipe/Bassani catback Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter 179.2 FWHP at 6900 RPM
Posts: 3,419 |
Posts: 760 |
How do I get this info?
jjh 2000 T-Red SVT #2134 of 2150
Posts: 216 |
00 Audi S4 Silver and Black (Bone stock)
98 Toreador Red SVT #742/6535 (Totalled)
KKM induction,Sho-Shop Y pipe, removed resonator, Superchip, B&M Short Shifter, Fog Light Fix 885 Fogs, Xenon Super Whites Clear Corners w/clear bulbs Removed Door Dings, TH Fix, ADR Phase II white 17s and Kumho rubber
Administrator
Administrator
Posts: 702 |
Originally posted by jjh: How do I get this info? There are two different ways... There's a sticker in the passenger side door jam, at the front near the door-open sensor. OR, you can look at the sticker on the PCM port cover under the glove box. Just peek under the glove box in the footwell. -Lance
