Posts: 536 |
im going to turbo my 97 gl but i need to know what the best location for the turbo is and how big of an intercooler will fit up front. Im goiong to be using a used TE04H turbo but i need to find a rebuild kit. Anyody know where i can get one? i would also like to know what the best intake setup would be. the compressor inlet will be facing the right side of the car and the outlet will be facing the front of the car. any info and pics would be very helpfull thanks.
97 contour gl mtx
front & rear upper strut tower braces
19mm bat sway bar
Koni struts w/GC knockoffs
Posts: 10,015 |
Try searching this forum!  You want to put a T4 onto a 4cyl (assumed from the fact you have a GL)?  You are in way over your head.  At least buy the book "Maximum Boost" by Corky Bell and read up on this because it's obvious you're going in totally blind from the turbo you picked for starters, as well as the other vague question you threw out there.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21,197 |
You could get a V6 GL in 97 stripped out. Vewy vewy rare. I'm guessing his isn't though.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 4,270 |
Originally posted by Plain ole' todras: You could get a V6 GL in 97 stripped out. Vewy vewy rare. I'm guessing his isn't though.
I wondered if they were real, there's a tour out near me for sale, the badge was GL, but had the 24v dohc emblem, and i wasn't sure if it was a real or not. Guess it's real.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 536 |
97 contour gl mtx
19mm bat sway bar
Posts: 7,025 |
Originally posted by striker2:
this is a small turbo capable of maybe 10-15 psi boost perfect for what i want to do (i only need about 10-12 psi to reach 200 hp). i'm aware that i would need a custom exhaust manifold and intake. my question is just what is the best way to route the intake?
that turbo is HUGE! If thats a 4 cylinder, youll probably just start spooling the turbo at 4,000 rpms. I suggest you may want to take a set back and think again about what your doing here, because youve picked one of the biggest turbos for your platform.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 1,224 |
Are you sure your thinking of the right turbo? Here's a map for a TE04H-13C.
It would actually almost be too small for a Zetec. At a PR of 1.5, at 6500rpms, you would hit 0.135m3/s. That's on the very edge of the map. It would be fully spooled by 1500rpm.
At a PR of 2.0, it would spool by 1900rpms but fall off the map at 5700rpms. A little small for that much boost.
If he's planning on sticking with the stock head, cam, and intake, it should be pretty perfect. There's really no room for expansion though.
BP
Ben ---'96 Contour GL * Zetec ATX * Tan on Black steelies---
+++JRSC M62 Under Construction+++
My big-a$$ mod list.
Posts: 10,015 |
Yeah but he'll superheat the air and effectively render the added boost useless, seeing as he is going to be WAY out of the compressor efficiency.
AUSSIE ENDLINKS $70
Posts: 536 |
Originally posted by ButtonPuncher: Are you sure your thinking of the right turbo? Here's a map for a TE04H-13C.
BP
Thank you buttonpuncher for backing me up on this. i do plan to stay with stock head, and cam.
the turbo is off an 89 plymouth voyager with the chrysler 2.5 turbo. i wont superheat the air if i send it through an intercooler
97 contour gl mtx
19mm bat sway bar
Posts: 10,015 |
A 16 y.o. turbo!?  Man that thing is bound to be worn out. YOu're better off finding a newer Garrett GT-25 off an Gen 2 DSM. Those are pretty easy to find, and are good for up to 14psi.
AUSSIE ENDLINKS $70
