Posts: 504 |
Macgyver is teh man, how dare you question him!
- 98 SVT #5999 -.
-CDA-7894 w/ ipod interface
-Knauberized, Trubendz 2.5/highflow cat
Posts: 508 |
The mscgyver directors actually had a few colleges around the country coming up with most of his easy fix situations. So, im assuming most of them, although maybe a little exaggerated, will actually work
Posts: 227 |
Originally posted by ancientsanskrit: Originally posted by PackRat: NERD!
Yep!
Ah, Harold Green, eh?
Ryan
'99 T-Red SVT, KKM, Borla, 1387 of 2760
'92 T-Red F-150 Flareside 4.9, 5 spd
'94 Geo Prizm, it was cheap
Posts: 2,445 |
Originally posted by rmcd79: Originally posted by ancientsanskrit: Originally posted by PackRat: NERD!
Yep!
If the women don't find you handsome, they should at least find you handy.
2000 Contour SE Sport
Originator of the Beowulf Headlight Mod and the Beowulf CAI
Posts: 1,367 |
Originally posted by TourDeForce: Thou shalt not use HIS name in vein!
Thou shalt not misuse "vain"!!
Sal Khan
00 SVT - Not pretty
00 Aprilia RSV Mille - Also Loved.
http://www.thelunchjournals.com
"I just want someone I can stand once her mouth is free of obstruction."
Posts: 777 |
Originally posted by ancientsanskrit: Sucrose structure:
I'm not very familar w/ the structure of Dextrose, but I think it's just the D-glucose (I'm pretty sure it's D-glucose, since normal glucose is L-glucose).
You are correct, sir!
Originally posted by ancientsanskrit: In any case, it's a carbohydrate as well and would occur with the same dehydration synthesis @ the glycosidic center.
However, there's no glycosidic center as there is with sucrose. I don't remember enough from OrgChem to remember which piece the H- would kick off... most likely kick the carboxyl group... though I don't know how that'd help the situation of a chemical leak...
--JamesT
--Chemguru
99 CSVT
Frost /Mid. Blue
00 Suzuki SV650
Red, Naked
Posts: 171 |
I suspect the writers of the show didn't remember their chemistry correctly. If you add concentrated (> 92% active in water) sulfuric acid to sugars such as glucose, sucrose, and dextrose, the sugar dehydrates significantly and swells into a blackened chunk of carbon (see link) http://jchemed.chem.wisc.edu/JCESoft/CCA/CCA5/MAIN/1ORGANIC/ORG18/TRAM18/A/PICTURE.HTM?1Hydrochloric acid cannot do this because you cannot increase the concentration significantly above 37% active in water. The sugar cannot dehydrate effectively in the presence of a lot of water. Mr. Spindlelegs
Posts: 1,746 |
2000 Contour SVT
SF - #542 of 2150
Posts: 4,016 |
MacMuthafarkinGuyver is the MAN!
2006 Mazdaspeed6
1997 Yamaha YZF1000R Thunderace
1996 Volvo 850-R
Posts: 1,384 |
--JamesT
Heh, I realized that shortly after! Good catch! Yeah, the carboxyl H should be deprotonated first, but as you stated, it really doesn't amount to anything significant.
Mr. Spindlelegs
Excellent point Mr. Spindlelegs. Hydrocholoric acid wouldn't be hydrated in that reaction. As I expected it would form Carbon/graphite, but I didn't realize HCl wouldn't do so, rather it is H2S04/Sulfuric acid. Good stuff!
99 Black Contour SE Sport
