#1327770 07/06/05 03:39 PM
going to change fuel filter. I found how to here, but got a question about one thing
"2) Turn over the engine a few times to be sure that the fuel lines have depressurized."
what is meat by turn over??? what will happened if i do not?
1998 Contour V6 Duratec 2.5L
#1327771 07/06/05 03:48 PM
"turn over" - crank the engine. The fuel lines are pressurized (fuel pump) and if you don't de-pressurize the lines, the gas is liable to "shoot out" (rather than drip) when you unclip the fuel filter from the lines.
#1327772 07/06/05 04:12 PM
gas will not shot out when you remove the lines but the filter will be full and you will have to deal with the gas that you spill from that and the line. not to much comes from the lines. I just put the caps from the new filter on the old one before I pull it out then drain the gas into a gas can
#1327773 07/06/05 04:29 PM
Maybe I should have used the term "squirt out" instead of "shoot out" but I would definitely not advise anyone to delete the "depressurizing the fuel lines" step before removing the fuel pumps.
#1327774 07/06/05 05:11 PM
E
E
I believe this thread is about the fuel filter.
When I did mine, I followed the "How-to" from the main site, and didn't have much trouble. I did get a face full of gas (which was fun) but that's because I was having some trouble getting the old clips off and my face was right there. Get the car way up there so you have some room to work.
MUST SELL - ECM computer new for a 98 V6 mtx + pats Now trolling in a Red Nissan 4 x 4
#1327775 07/06/05 05:27 PM
Bah! Pu$$ies. I just pull the 2 clips and loosen the clamp. Get a little gas but no big deal. Takes 5 minutes.
#1327776 07/06/05 05:51 PM
yep that's how i've always done mine...i've never felt the need to depressurize nothing...just pull the clips off and be done with it..
new,new ride! '99 svt black/mnb '95 mustang gt sold! '98 svt #800 sold!
#1327777 07/06/05 06:18 PM
it's so easy, i'm usually not even finished smoking a cigarette by the time the filter is changed!
#1327778 07/06/05 07:39 PM
I'm also new to this and actually did this fuel filter change this past Friday. Just follow the HOW-TO and you won't have any problems. It literally takes 5 minutes or less. Scale of difficulty is not even a 1!
#1327779 07/06/05 07:48 PM
Well you could put it in backwards if you are a complete dolt.
