Page 2 of 2 1 2
#1327209 07/12/05 12:28 PM
Originally posted by Ryan:
do you think there is a connection with the turn signal messing with the brake lights somehow also?
Since the brake lights (except the 3rd one) go through the MFS, then it is pretty likely that this is your case.
If the 3rd lite works but the corners don't suspect the MFS or its associated wiring/connectors.
Steve
#1327210 07/13/05 01:39 PM
i had problem with back lights also about a week ago.
problem was with a turn signal switch. take the covers off and take a look at connectors(for starters). i found burnt wires there...
1998 Contour V6 Duratec 2.5L
#1327211 07/13/05 02:05 PM
I went through this a couple of weeks ago. F23 and F24 kept blowing when turning my turn signals on, which caused my brake lights and turn signals to go out. The dealership replaced the multifunction switch, which fixed it for approximately 3 minutes. On my second trip in (couldn't drive the car all 4th of July weekend because of no brake lights or turn signals ), 6 shop hours later they were able to find the short that was causing the fuses to blow (and therefore, concluded that this short also caused the MFS to fry as well). Right where the driver-side rear seat folds down there is a cluster of wires running to the back, and over time the folding of the seats had worn the insulation off of the wires, causing the short. You may want to check there and see if those wires are worn down. If they are, fix them up, replace the fuses, and see if that helps. If not, you may want to look at the MFS.
Page 2 of 2 1 2
