Posts: 10 |
Hey -
I'm trying to figure out if my engine has a overhead cam or not. How can I figure this out? I have a 1995 Contour SE.
Thanks
Posts: 7,025 |
yes, its a dual overhead cam.
probably even has "24V DOHC" badge on the each front fender.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 24 |
The duratec v6 is DOHC (that's: Dual OverHead Cam)
Posts: 319 |
not only are they overhead, they are dual and they are hollow
Posts: 7,117 |
The Zetec 4 cylinder engine is also a dual overhead cam, so all Contours are DOHC.
Posts: 1,687 |
Not only is it an overhead cam but it also retains the coveted title of "quad-cam". I envy you. Well, maybe I just want your car.
It's a good thing Ford didn't put that hideous Split-Port I4 in the Contour/Mystique. The Focus still got stiffed into production with that POS.
J.T.
2002 Chevrolet Silverado 294ci V8. Custom CAI, headers on the way...
1997 Mercury Mystique Zetec ATX
Deceased February 2006
Posts: 10 |
Originally posted by MadMerc97: I envy you. Well, maybe I just want your car.
You can have it. I think it has a cracked cylinder block and my friend was telling me if it wasn't overhead cam, I could probably fix it myself but being it is hallow dual overhead, I think the car may be headed to the junkyard. I'm quoted $1000 + block from any garage. I'm bummed.
Posts: 4,140 |
Get a 3.0L block and make it worth it.
Posts: 1,456 |
If it's a Duratec V6 it might be worth fixing it if you like the car, and it's not beat up otherwise. Or someone might want to buy it as a project. Like here: vehicles wanted
http://www.contour.org/classifieds/classifieds.php?t=2&c=2 Which would be better than junking it. What happened to the engine? Did it overheat?
