Page 2 of 4 1 2 3 4
#1326981 07/06/05 03:07 AM
You can win easy even though he has posi, IF...
You raise rear of your truck so your hitch is several inches higher than his, AND use a relatively short length of chain - 10' or less.
When you start pulling, the extra height of your hitch will raise the rear of his truck while planting yours. The shorter the length of chain, the bigger your advantage.
Sneaky, I know. I like it that way...
#1326982 07/06/05 03:11 AM
I've always loved the way you think, TDF..
always.
Ray
#1326983 07/06/05 03:15 AM
always.
Ray
Thank you most kindly. That is high praise, indeed, coming from 'Ray the Almighty!'
#1326984 07/06/05 04:23 AM
O
OB1 Offline
O
I thought we only did stuff like this in the south!
Really you've got him in all fields except wieght and if you've got a bed cover you could sneak some stuff in there to "level the field". You've got a good chance but nothing is a positive. I've driven durangos but never any towing, but I've got an 03 ram with the 4.7 and it is geared pretty low, but i haven't done any towing with it either! Good luck.
I don't "mod" I just fix what breaks! 98 CSVT #2527 T-Red (Limping) 98 CSVT #2228 T-Red (Donor) 98 SE Sport ATX V6 (Running again) If swimming is good for your figure, explain whales to me!
#1326985 07/06/05 04:51 AM
Throw a load of something in the back before you take him on. That ought to give you a bit more traction. And throw it in 4WD.
Funny stuff!
99 SVT Contour Silver Frost, #365/2760, DMD 98 Audi A4 2.8 Quattro Tiptronic, 30V -- SOLD! 91 Isuzu Impulse XS Kammback, Handling By Lotus Victoria, BC, Canada
#1326986 07/06/05 05:09 AM
stop by home depot and grab some bags of gravel. they will seriously add some weight to the rear of your truck. hopefully he wont b*tch about you not running it in "stock" form.
if youre seriously teetering on this decision and have a good amount of money to lose then maybe consider renting the same vehicle and doing a secret test run before-hand. or finding someone with the same vehicle and paying them to do a trial run with you. all the theorizing in the world wont help you like the real thing. sounds like a risky bet
ps just out of curiosity...
we dont have these kinda hillbilly activities out in these parts so im curious if this can f*ck up something on the trucks?
#1326987 07/06/05 11:56 AM
Definately.
#1326988 07/06/05 12:00 PM
2
I would say don't do it, this was a big thing back in my home town until one day the chain snapped and came back at one of the drivers' heads. he was in the hostipal for nealy a month
Derek Johnson 88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3 95SE 3L gone
#1326989 07/06/05 04:00 PM
or somebody pulls someones bumper off
96' ATX Zetec- stock 96' ATX Zetec- Modded Kenwood KDC-319 5.75"-2 MTX 12's Roady XT Custom door panels Mystique Cluster/oil pressure Getting repainted(in primer) Pre98 Lip SE skirts Mystique front lip dingless badgeless
#1326990 07/06/05 04:14 PM
last I checked, a towing-capacity type truck didn't have the hitch on a bumper like an explorer, etc
Ray
Page 2 of 4 1 2 3 4
Moderated by  mbb41_dup1
