#1326394 07/05/05 01:16 PM
swdubs Offline OP
I am working on a 1999 Contour with the V6. I am getting the low flow to the EGR error code. I replaced the EGR valve, cleared the code, but within a day the check engine light came back on. Can it be carbon built up in the tube ?
Thanks,
#1326395 07/05/05 01:30 PM
2
Carbon build up has always been the problem I had on my 2 V6s. Get yourself some gaskets, carb cleaner - the good stuff like Berryman's or Gumout. something to scrape the carbon out with and a piece of mechanics wire to run through the passage from the TB to the EGR valve.
#1326396 07/05/05 01:40 PM
Use the search function and type in your code # , could it be P0401, or P0402? If so you may have replaced the wrong part. Next time you have the codes pulled post them here if you need help. BTW who told you to replace the EGR?
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760. "Many posted questions are answered by farm boys"
#1326397 07/05/05 02:32 PM
swdubs Offline OP
I lost my notes, but I beleive it was 0402. What parts should I have replaced ?
Thanks for the responses
SW
#1326398 07/05/05 03:31 PM
EGR failure is VERY uncommon..
more likely causes are CLOGGED EGR's, clogged EGR passegeways (including inside edge of the TB) and a faulty DPFE
Ray
#1326399 07/05/05 09:50 PM
Welcome to the site!
All engines with small EGR distribution passages behind the throttle body are subject to clogging.
As a matter of fact, you would also benifit from an intake cleaning and MAF cleaning Check here .
