Page 1 of 3 1 2 3
SVTake2 Offline OP
Well its been a very long month that's for sure. For those not in the loop one month ago my 3L was dropped in and hooked up ready to fire. Unfortunately due to an incorrect Mitchell repair manual timing chain index diagram and my stupidity for not checking properly, there was a valve to piston turf war and the piston won. Fortunately only the rear bank of intake valves were damaged. UN-fourtunatly that required me to pull off the same parts i just assembled on an engine stand while the engine is stuffed in the engine bay . Not a bunch of fun.
Long story short it was alot of work, and while I had things apart i replaced the shift cable and had the injectors tested and cleaned. I also went to install my recently ordered MSDS Y pipe only to learn about the whole two different flange thing. I have 3 holes, but i only need 2.
Once i got things running it was just a matter of putting the body and interior back together. I was so excited to finally take the masking tape off my gauges and put my cluster creation into its home for the last time. I am so happy with the way it turned out, its just how i wanted it to look. But it took alot of fiberglass, bondo, sanding, drilling and painting to get it that way . Also the silver circle by the defrost button is a shift light.
Today I took it to a shop to have an alignment, resurface rotors, bleed brakes with new fluid and mount a set of new Toyo Proxes4. As it sits right now the only problem i have is the coolant light is on. It also seems to be running a bit hot. I notice max water temps of 200-215 (only a few short trips so far) and the coolant boiled over on me once. I'm not sure if these are symptoms of air in the coolant system or what exactly. I am going to have it checked out and to see what is tripping the light specifically. Also the brakes feel really mushy even after the bleeding. They don't take up until deep into the pedal travel and even though it stops ok it feels like your stepping on a month old watermelon.
Other than that its running damn good for something I put together lol. There are no other warning lights on the dash besides the coolant, the clutch is strong with good take-up and the engine idles relative smooth (as smooth as polyurethane motormounts will allow ). I'm still running on the stock 2.5L SVT ECU tuning so I have been very light on the throttle. I haven't been over 4000 rpm. I am having a custom tune done on the dyno next week but until then should I be hesitant to put on miles?? I need to drive a few hours out of town to get to the dyno, It should be fine no?
Broken Lifters, Ouch!
Piston Vs Valve.. Ding ding ding we have a winner.
My nightmare
Remote oil filter and bracket. The tab mounts under one of the left hand motormount bolts.
A running Engine, Valves and pistons are getting along fine
One of these things is not like the other.
Interior.. Not looking so hot
Interior� Much better.
In all her glory.
Dog head out the window on the maiden voyage
Thank god for CEG and all the great guys for answering my stupid shoulda searched more questions. There is no way in a million years i would have been able to do it without this great resource. Extra special thanks to:
Pale Horse
SVTprodigy
Haines Motor Sports
DemonSVT
dumpedSVT
Stazi
98.5 Black contour // A.K.A. Frankenstein 3L Oval port swap W P&P // SVT UIM, LIM, & Cams Torsen LSD // Dual Friction // KKM // Poly Mounts // ?Mystery Mod? // Actually Running! 205 hp @ 6500RPM 180 tq @ 4250RPM
Great job man!!! take her easy at first but as soon as you feel comfortable let er rip!!!!!
99 T-RED 3L SVT Apillar Guages How-To 3L 98 CSVT SF/MB 4 SALE 7500 obo pm me
good job, sorry about the troubles, but looks like you got most of them worked out...good luck on fixing whats left to fix.
btw those gages are
Goonz12: <---tries on mommy's cloths
that guage setup makes me
Mike C T-Red 99 csvt #490 No longer a dailer driver
Awesome! Too bad about the SNAFU with the valves, but at least it's sorted out. I like the gauge pod - very unique and cool!
The last pic of the dog made me laugh. Dogs are cool!
Nice pics, cute dog, and gauge cluster.
W
W
Really nice gauges! How well does the color match in sunlight?
This may be a crazy q but do you have the coolant filled above the max line about 1"? Needs to be above max for the light not to come on. An old Contour quirk. Sounds like you ahve air in the lines as well, WP issues or the fans aren't coming on.
SVTake2 Offline OP
The colours match really well durring the day. And durring the night they look great to. They have the same green glow but insdead of the numbers backlit there is just a green glow from the outter rim. They are phantom series gauges. I took power for the lights off of the headlight switch so they go on with the rest of the dash lights, but I think I need a seprate dimmer switch for the guages, they are a bit bright. Do you think i could just splice into the stock dash dimmer switch?
i noticed you had the kkm intake. while i had that on my 2.5 and it worked fine, ive heard from some (specifically from Roz 1999 SVT-C) that the KKM imploded with their 3L's
Page 1 of 3 1 2 3
