not the best way to check it but spray some starter fluid into teh throttle body and crank it to c if it starts, if it starts its a fuel problem if it doesnt its prolly ignition related.
can u hear the pump hum when u turn teh ignition to accesories not start
it may not even be ur pump , c if the fuel pump relay is bad, check all ur fuses c if anyone blew etc
1997 30th Anniversary SS,Jethotts/ORY/GMMG, 160thermo, ,TB bypass, 1LE intake elbow, BMR STB, 32mmswaybar..21mm rear,BMR LCAs, PR,SFCs,TA,LT4 KM,255lph, shift kit
