I was searching some old posts and they where taking about the tss switch. Do you think I should try this first and a fluid change before I take it to a shop? Also i wraped duct tape around the od button depressing it at all time and this works no od light at all but now that it is getting hot out side the tape isnt holding like it did in the colder months. Since holding the button in fixed the problem that why I thought it was faulty button so I disconected the switch drove it for like 15 min...speeds up to 100 mph and no od light but when I hit a bump in the road it came on and stayed on and the car switched to 3erd gear. I pulled over shut the car off and started it again and the light was off. havent drove the car since to see if it will do it again. Do you think changing the tss will help me since they revised it. thanks for all your help.
Pete
