Posts: 1,356 |
Obi, I thought you had a 2.5?? Is it a hybrid??
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 5,975 |
Originally posted by Y2KSVT: I'm right behind you, 2 years!! Even when I replaced the downstream O2's and yes, I have MIL's, I still have the CEL. The codes were for downstream O2's..
I'm in the same boat as you.
Posts: 661 |
Originally posted by 99Mystique ATX: Obi, I thought you had a 2.5?? Is it a hybrid??
no
Fast Cheap reliable
Pick two
Posts: 1,356 |
Oh... So that was a 3L that you were running low 14's on before then??
I'm assuming that was a no to both questions??
1999 Mystique LS V6
Posts: 548 |
coming up one 3 years with a CEL myself, if it wont pass e test because of the code ill yank the bulb
98 contour gl, v6 auto
01 explorer sport v6 auto
2001gtp AT gmail DOT com
