#1322850 06/30/05 04:47 PM
I don't get any air flow thru the panel vents. When I turn the knob to panel it continues to blow air thru the defrost vents. Has anyone had this problem before or any suggestions on how to fix it??
1998 BLK contour sport 5 speed
#1322851 06/30/05 05:26 PM
If you go to Search, Troubleshooting, type in the word Defrost, and set it to past 3 months or so, you should get a ton of info for this problem.
Good luck.
#1322852 06/30/05 05:28 PM
EVERYONE has had that problem, and the fix is commonplace... a quick "search" under troubleshooting for "defrost only" or "no panel a/c" or the like, would have turned up that your AC operates on the presence of vacuum or no-vacuum. The default location to route air is the defrost panel, and that is when there is no vacuum applied.
You likely lost your vacuum connection, and therefore are experiencing this. The search would ALSO have turned up that you can check the vacuum dash pot from the passenger side, behind the radio area (look between the firewall and the console, for the hard plastic vacuum tubes. One likely fell off of the pot itself.
Ray
#1322853 06/30/05 05:59 PM
And if you want a picture, Main Site, FAQ, Common Problems, Interior, Air only ...
