Posts: 3,636 |
I've rigged my tripod as a "passenger". I'm using the passenger seat belt as a hold down strap, with a car-seat seat belt friction holder to keep the tension on the belt. I've lengthened the three legs to meet the floor/tunnel around the passenger seat.
It appears pretty sturdy, and will test it out on the drive to SpringZing. Hopefully it will be allowed on Gingerman and the AutoX.
I was just wondering what others do for solo, in-car video.
TB
Tony Boner Personal: 98cdw27@charter.net Work: tony.boner@sun.com Saving the computer world from WinBloze as Unix/Solaris/Java Guru http://www.sun.com 1998 Contour SVT Pre-E1 618/6535 Born On Date: 4/30/1997 Now with Aussie Bar induced mild oversteer.
Posts: 4,042 |
I've seen guys (Mustang) put the tripod in the back seat. 2 legs behind each seat (driver and passenger) and the 3rd leg fit snugly into the middle of the seat. (between seat and back cushion) Hold everything down w/ a couple of straps and the seatbelts. Not sure if it'll work w/ a Contour though... Also, few places on-line sell tripods and some sort of attachements specially designed to go in a car. Don't remember where though... IF you Auto-X a lot, might be a worthy investment... EDIT: This *might* help... http://members.cox.net/mkpl/carmount.html John
Posts: 2,847 |
Best one I saw used the headrest poles as for mounts. Basically it extended off of the passanger seat headrest to the middle of the car where the camera was mounted
Posts: 3,636 |
I can't sleep so I put it in like this:
Posts: 3,636 |
Originally posted by Eric L: Best one I saw used the headrest poles as for mounts. Basically it extended off of the passanger seat headrest to the middle of the car where the camera was mounted I was thinking of that too, some of that box steel with the holes in it. Perhaps I'd have to open a few of the holes to get it to line up with the brackets on the head rest. Or just go with stock that doesn't have the holes and drill them in the right locations.
Posts: 270 |
u might wanna wrap a few straps around the back 1-2 pegs...keep it really secure when u corner
Black 98 Contour SE Zetec ATX 5% Charcoal-black tint (tint on exterior and interior) Knauberized on 5-05-02
Posts: 376 |
I took a piece of 2x2 (i think) that we had left over from building our deck (the vertical pieces for the railing) and drilled a couple holes for the headrest posts and then modified one end so that a window mount for a camera will clamp on. i took it down some twisty roads to test it and it seems to work great. sorry no pics, so i hope the description works for ya.
~Shawn Clone~
1999 SE Sport V6 MTX Silver frost/Midnight Blue BAT Euro Handling kit, SCA Cold Air intake, painted dash/calipers, Elky's mesh grille, bulitt fuel door,B&M shifter, ES motor mount inserts, OMP front strut tower brace, newest mod- HPP rear strut tower brace ...coming soon, Aussie Bar Possabilities in the works: Custom CAI, Polished stainless shifter cover plate
Posts: 1,507 |
Mine is ugly as ph-uck, but whatever works. I just threw it in to take some pics of it, when I have it in for Gingerman I will use the seat belts and maybe a bungee or two to hold the tripod.
-- Mike (Moe)Lester -- 98.5 SVT #5486 moesvt@comcast.netGet your a$$ on IM and stop wasting bandwidth!!!!!!
Posts: 5,296 |
They look like they're going to fly all over the place when you take a 1G corner!
Posts: 1,507 |
Originally posted by AirKnight: They look like they're going to fly all over the place when you take a 1G corner! It's actually much sturdier(sp?) than it looks. The tripod holds the camera, and the wood bracket holds the tripod, and the seats hold the wood  .....and like I said, when the seatbelts and tie-downs are added, it doesn't move....hopefully My wife keeps Bitchin', saying that the camera is going to go through the window :p
