Posts: 5,975 |
I can't seem to find them available for purchase...
If not, any similar IB recommendations?
Posts: 2,353 |
Adire has recently opened a new build house down in Chile or Argentina, the result of which is that they have stopped producing speakers for a time. Last I heard, they are getting ready to offer a whole new production of speakers that will have many new offerings and be quite a bit more expensive. I don't think that they will be selling speakers direct anymore either, from now on you will have to go through a dealer. An option for you might be: Elemental Designs 9Kv.2
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 5,975 |
Thanks path.
I think the .30 qts might be a little low for IB?
I'm thinking:
Dayton 8 Quatro
QTS = .40
Xmax = 9.5mm
RMS = 150w
Price = $49.72/each
I feel Guilty, Oh so guilty
Posts: 4,789 |
Onkyo 8" at www.apexjr.comor the other 8 listed there. Or, maybe the TB X8-740C or RE8 from www.respl.com
-Mitch Hedberg
Posts: 2,353 |
All good options so far, although my experience with the RE8's has been lukewarm, they seem to have very low power handling (I've seen two and heard of a few others that have blown running on RMS power)
2003 Suzuki SV650s
Posts: 1,356 |
I'm going to give the Tang Band 6.5" "subwoofer" a try from Parts Express. I'll order one when I get back from work today. I think it should be a pretty good choice. I'll be sure to post pics and results.
Specs look pretty good... Xmax 11.5mm Fs 35hz Qts .37
Qts could be better, but I think it'll be ok...
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 2,353 |
Originally posted by SVT PETE: Originally posted by path914: An option for you might be:
Thanks path.
I'm thinking: Dayton 8 Quatro QTS = .40 Xmax = 9.5mm RMS = 150w Price = $49.72/each
If you want a higher Qts. 8" woofer then the MTX from PE might be a good choice for you:
MTX 5500
2003 Suzuki SV650s
Posts: 10,015 |
Originally posted by path914: Originally posted by SVT PETE: Originally posted by path914: An option for you might be:
Thanks path.
MTX 5500
Is this MTX suitable for a free air/rear parcel shelf setup?
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 2,353 |
Really any speaker can be run free air, but a qts. above .5 is usually recommended. The MTX would be fine as would the Apex Jr. that Dave suggested.
2003 Suzuki SV650s
Posts: 10,015 |
AUSSIE ENDLINKS $70
