Posts: 240 |
my friend has one and hes got a exhaust and a intake, and he wants to race me, im wondering if you think i got a chance w/ my se sport
1999 T-Red Contour Sport w/ 78000 miles
Posts: 786 |
ATX or MTX? Do you have any mods?
Posts: 9,065 |
I know of ONE Zr2 manual. It is owned by my friend taylor and it is a one off. You should be able to walk him.
Posts: 6,106 |
You want to race a blazer?  You just earned a big fat  Mark
2000 Black CSVT
Posts: 3,840 |
ZR2 is an off road suspension package. It has nothing to do with the engine under the hood.  -SAV
Troll. 1997 VW Jetta MkIII GLS 5spd
All hail my appearance on CEG!
Posts: 3,345 |
Originally posted by SAV: ZR2 is an off road suspension package. It has nothing to do with the engine under the hood.
-SAV
The higher it is off the ground, the faster it is. Obviously.
1996 MM
Zetec, ATX
192000 kms...not dead, but I'm not fixing it
White people love Wayne Brady because he makes Bryant Gumbel look like Malcolm X.
Posts: 1,055 |
Originally posted by MapOfTaziF�³sh�³: I know of ONE Zr2 manual. It is owned by my friend taylor and it is a one off.
I think you're wrong Pete, we had one int eh shop the other day.. and I must say he was complaining of a high rpm stumble. so while driving it didnt seem slow at all esp for an suv. Watch out if you cant drive stick too well or have an auto.
Derek Johnson
88 TurboTBird 32psi, t3/t4 bb 50trim, megasquirt, 3 bar map, 50lb inj, roller cam w adj. gear, header, 3" downpipe and full exhaust, gutted intake manifolds, spec stg 3
95SE 3L gone
Posts: 2,446 |
most zr2 s10/blazers come with the 4.3, which is not a slow poke for the weight they are moving. Also, zr2 is the offroad/4wd package. While 4wd means nothing for racing, im sure it has a stiffer suspension, so it that may help.
Posts: 175 |
Originally posted by ZR2.com:
If you are wondering what makes a regular S-10 a RPO ZR2, the following is the list of the factory modifications:
* RPO ZR2 only full ladder-type frame with modified suspension mounting points which provide:
* 100mm wider track (3.9 inches wider than regular S-10)
* Three-inch suspension height increase
* Enhanced front (7.25" ring gear) and rear (8.5" ring gear) axles w/ 3.73:1 rear-axle ratio
* Larger wheel and axle bearings
* 31 x 10.5R-15 LT/C black wall off-road tires (BFG A/Ts on pickups and BFG Long Trails on BlaZeR2)
* 46mm gas pressurized Bilstein Monotube shocks
* Rear axle track bar (pickups) / rear sway bar (BlaZeR2)
* Wheel flares (black on S-10 pickups and BlaZeR2 / body-color on Sonoma pickups)
* 33mm (early model) / 28mm (late model) front anti-sway bar
* Skid plates
I know that the 4.3 max Torque is 250 @ 2800 and HP is 190 @ 4400 Weight 3700-3800 lbs
98 Contour GL 4 cyl 131,000 miles
- 57,000 w/o a CEL!
Get Firefox
Posts: 6,700 |
Two words... "YEEEEeeeeee Haaawwwwww" Personally, the ZR2 Blazers are one of the fugliest SUV;s available. The manual trans was offered in the first year of the new body style Blazer and was a complete flop. WHy someone would race a blazer is beyond me.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
