Page 3 of 5 1 2 3 4 5
#1317123 06/28/05 04:21 PM
My old Contour had my dual-tone Grand Marquis horns on it. Man's car all the way around. Wish I'd stripped them off...
#1317124 06/28/05 05:03 PM
Z
Z
you could always attach a bike horn to the steering wheel! haha put that in the direct bolt-on section! i agree though the tour's horn is weak. It almost makes the car sound like a sqeaky toy for a dog.
1998 SE Duratec V6 ATX Ebay intake with K&N Filter Trubendz Exhaust Custom Hood
#1317125 06/30/05 04:37 AM
Just 98+ is weak.
#1317126 06/30/05 05:17 PM
Originally posted by big_red:
lol, train horns , u guys crack me up )
I heard an F-350 with a train horn today blasting at someone to get moving in the turn lane. It was awesome.
#1317127 06/30/05 05:25 PM
V
V
How hard are the aftermarket horns to install?
Silverfrost 99 SE Sport ATX
#1317128 06/30/05 06:54 PM
Disconnect old horn, reconnect new horn.
#1317129 06/30/05 07:01 PM
V
V
Oh ok thanks. i didnt know if there was any wire splicing involved, or anything like that cuz im not the best at that. Thanks.
#1317130 06/30/05 07:16 PM
Since I was replacing a single horn with a dual, I had to do more than that. I removed the bolt that mounts the factory horn to the brace. I used that bolt to mount both of the horns to the brace (one rightside-up, the other upside-down) with a nut on the other side. I made a splitter adapter (since I didn't want to splice) using a butt and 3 slot connectors (1 female for the power side, 2 male going to the horns). I used 1 ring connector for each horn for the ground (the factory horn grounds through the bolt -- no ground wire). I pancaked both rings and put the mounting bolt through them, then through the brace, then tightened up to the frame. The relay that came with the hella horns appeared to be the same as that factory relay, so I didn't use it.
The female slot connector had a harder shell and the factory power slot connector wouldn't fit in it (it's rectangular), so I had to shave the corners off. A softer shell probably would have fit around it without any issues.
morbid 2000 Contour SVT (black)
#1317131 07/04/05 08:53 AM
H
H
My '97 Mystique has a nice, well balanced horn. I like it because it isn't high-pitched, but it isn't a tugboat foghorn either. Just perfect. Maybe it's a Mercury thing. one of those "notch above Ford trim" lines of BS I keep hearing from magazines and salespeople.
#1317132 07/07/05 03:53 AM
NEED AN SVT REAR BUMPER!!! pm me
