Posts: 34 |
OK iv'e seen this before. Does anyone know who fit the 13" Baer kit into the 17x7 FSVT wheel on the contour? I would like to know how to do this.
Posts: 6,106 |
I think it was ScottD? I'm pretty sure the only thing you need is a 1/4" spacer.
Mark
2000 Black CSVT
Posts: 7,025 |
i believe youll need some spacers for the front as well.
Jim Hahn
364 whp, 410 wtq @ 4,700 rpm
Posts: 5 |
Any one know of a good place to get spacers?
Working on life
Posts: 3,867 |
Originally posted by Tom D: Any one know of a good place to get spacers?
H&R?
Function before fashion.
'96 Contour SE
Posts: 6,760 |
I'd try Todd @ TCE Originally posted by Tom D: Any one know of a good place to get spacers?
Ryan
Trollin!
Posts: 1,423 |
Originally posted by Y2KSVT: I think it was ScottD? I'm pretty sure the only thing you need is a 1/4" spacer.
Mark
~1/4" spacers and longer wheel studs...can be found at just about any auto parts store.
Longer studs are needed "ONLY" if you require spacers for your wheels to clear the calipers. Some wheels will not require spacers and therefore will not require longer studs.
If you require spacers and longer studs the wheel studs you need are from 92-86 Mazda RX-7
Item Number: 610-341 Description: Wheel Studs Brand: DORMAN Application: Mazda 92-86 Type : Serrated Stud Thread : M12-1.5 Knurl Dia. : 13.08mm Length : 52mm Shoulder Length : 25.5mm
Scott
2000 Contour SVT #1464
Mustang Dyno: 171.6hp/145.3lb
Dynojet Dyno: 171.1hp/148.9lb
1989 20th Anniversary Turbo T/A "Indy 500 Pace Car"
#1376 of 1550 All Original, 46k with a few mods
2002 F150 SuperCrew
