Posts: 1,355 |
I wash my car every week, Lately I have been waxing also each time I was my car. I have read alot about detailing your car and stuff on the web and they say that waxing should be done, normally, on a 3 month cycle  . Is waxing your car EVERY week bad for your car? Is it worth it or am I just waisting my time? It seems to be doing alot for my paint, color looks deeper and alot more "mirror" like. I do use Meguiar's quick detailer every other day just to keep it like that. Should that be enough after a wash? Any opinions on this would be appreciated.
Simon W. Las Vegas. 96 SE V6 MTX Tereador Red (1st Blown Engine, better be the last!) 1999 SVT Engine SVT Exhaust w/custom DTM Tips and optimized Y-pipe and no Res (thanks to Po-Jay!). LSD Quaife(thanks to Terry!), SCA CAI w/KKM, Grizzly clutch, FMS 9mm wires, Airknights custom short shifter.
"You can only get more rice at one time by ordering Chinese" - Davo7SVT "it's only nuts and bolts" - Terry Haines "Drive it like you stole it" - Me!
Posts: 13 |
The quick shine stuff will be quit sufficiant. It depends on the type of wax you use when it somes to how much to use. With a carnuba based wax (which will tend to build up) it will take more & more time to wax it to were it looks good. If you are using a hand polish (which is a little more agressive) over time you are actually taking a little bit of clear coat off each time. The ideal thing to do is use them in conjunction (first hand glaze then wax ((I like Mother's Carnuba paste wax myself))every time, every two to three months.
Credentials: ASE Certified I-CAR Certified With experiance in auto body & frame repair, automotive refinishing as well as metal bonding, plastic bonding & welding
My Car: '93 Probe GT with NO modifications.
"Now you see why I ask alot of questions."
Posts: 474 |
Every week is a little excessive. A good wax job will last quite awhile depending on what you do to your car. All wax does is protect the paint, polish brings out the shine.
-= Kevin =-
•¤• '01 Black Explorer SportTrac •¤•
Posts: 304 |
i say too much is when you cant open the door because your hand keep sliding off the handle.
I can read your mind , and you should be ashamed of yourself:p
Posts: 2,906 |
Originally posted by wanabe: i say too much is when you cant open the door because your hand keep sliding off the handle. LMAO once a week is very excessive. Try every 2 months or something and just use your quick detailer every week after a wash. You don't want lots wax buildup.
Josh Aka Spectra SVT 02 Dark Highland Green F-150 XLT Mods: Gunrack and cowboy boots
Posts: 1,355 |
Originally posted by wanabe: i say too much is when you cant open the door because your hand keep sliding off the handle. LOL....I'm nearly there but not yet! :p
Posts: 770 |
I wax once when spring hits, once about half- way through summer, and once right before the winter hits. I find even this is adequate and I use a quick-detail spray to keep it looking good in-between the big wax jobs... Before I wax, I strip everything with a nice detergent soap and a pre-cleaner paste, too... piles of old crud and oxidized paint/wax don't really do anything for your finish! So yeah, IMHO, you're waxing too much.  T.
Posts: 1,355 |
Originally posted by Kevin: Every week is a little excessive. A good wax job will last quite awhile depending on what you do to your car. All wax does is protect the paint, polish brings out the shine. So polishing is ok but not wax? What polish do you recommend?
Posts: 3,584 |
Well Simon I'm VERY exsesive then because I do my car about twice a month  I use Mequiers #26 Hi-Tech wax, Zymol cleaner wax and this Dupont glaze which ever I feel it needs. The cleaner wax will take out swirls and slight imperfections in the paint and the glaze waxes are more for shine than protection. I've done my car about 9 times since the spring and my car ALWAYS looks good. A detailers tip to you, use the foaming armor all stuff in the wheelwells for that finishing touch. It also works GREAT on the engine compartment but make sure that the engine is cleaned before spraying it on there and wash you car immediatly afterward so that you wash off the over spray from the aresol can Roger R US Mondeo@aol.com
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 275 |
Polishing is usually a step before waxing. I try to do a thorough detailing once (or twice) a year, where I use a cleaner, then a polish, then a wax. After that point, if you're using a good car shampoo (like Meguiar's), it should clean off everything that's on the surface, except the wax. Then you just need to quick detail it and it should be as good as new. If you're washing and quick detailing it on a regular basis, you probably can go 2 or three months (depending on your climate and how picky you are about your cars appearance) between waxing. My $.02, hope it helps.
95GL25
