Page 2 of 2 1 2
Strong Offline OP
Originally posted by fazzman:
Well no problems with mine. The door isnt touching bare metal, there is a layer of paint and clear coat also the glue holding it on. So whats the problem?
That actually will be sufficiant, just so long as you use the plastic washers. By the way guy, how does it look? Send us some pics. Don't hold out on us.
Credentials:
ASE Certified
I-CAR Certified
With experiance in auto body & frame repair, automotive refinishing as well as metal bonding, plastic bonding & welding
My Car:
'93 Probe GT with NO modifications.
"Now you see why I ask alot of questions."
As any former owner of a Chevy Vega can tell you, galvanic corrosion is a BIG problem. The Vega had a steel hatch, but an aluminum frame around the rear window. Despite the fact that the hatch was painted before assembly, over time the inevitable would happen, and the hatch would rust through all around the aluminum frame. (Being a basic idiot at the time (and still), I repaired mine by filling the numerous holes with exterior wood putty!) So beware the fuel door, even if the paint is sound, without some sort of buffer gasket. As to the bike issue, I think the corrosion is greatly helped along by the presence of an electrical current. Cars' bodies carry the power ground, bike frames usually are not powered, so that could account for the difference. But I defer to the engineers in the group on this one.
2000 Contour SE Sport T-Red MTX, Mystique rear dome light, Blau Florida cd.
Page 2 of 2 1 2
