Posts: 2,657 |
Wow, those look great! Where did you get them from? Have you had any problems with heat from the HID? ie...melting wires, warping plastic, paint??
Posts: 4,983 |
Quit ****ing posting those David! You're gonna make me want to get HID too!
P. Valdez 1998 VW Jetta TDI 1.9L I4 direct injection turbo diesel 5 speed manual no mods, no money AIM:PackRatTDI My exhaust smells better than yours.
Administrator
Administrator
Posts: 5,037 |
Hey David, are you going to get yellow foggies as well? That would look even better! Great job on the HID!
Posts: 770 |
Originally posted by SQPlus: Wow, those look great! Where did you get them from? Have you had any problems with heat from the HID? ie...melting wires, warping plastic, paint?? IIRC, HID burns very cool.
Andrew 99 SVT
Posts: 76 |
where did you get your hid kit from? how much did it set you back?
A.J. (Scratch) 2000 SVT Black/Prairie Tan (Guinness Edition) 147/2150 KKM Tru-Rev Motorsport 9mm Wire Set PIAA Super Whites Amber Fog Lights Razo Carbon Fiber Pedals Richbrook Shifter/Em. brk AOL Im:AFrint7065 phrint@hotmail.com
Posts: 1,108 |
Very nice :)All you have to do is change those fogs now
Kick Ass don't Kiss It
Posts: 2,166 |
SQPlus : Thanx! www.xeononshop.com, sorta... the 9006 adaptor was glued on with superglue and with the heat they have come loose. When that happens they go out of focus and look really nasty. I tried using some cement and will see if that works. I would recomend autolamps-online.com they use a custom molded base. Other than that, no other problems... PackRat : :p Chris : yeah, I think I just might do that... can I use a "yellow" bulb or do I have to switch to like PIAAs? scratch : www.xenonshop.com $550 shipped, again I would try a autolamps-online.com kit instead of the jinky kit that I got kool aid : Are u using yellow fogs? is it just a bulb change?
Posts: 2,657 |
I'm using 'Di-Chroic' Fogs and the lens is what colors the light. Mine are yellow. The bulb is a standard bulb. H3 I think
Posts: 2,657 |
I just stopped by autolamps.online.com and it looks like the 9006 kit is $600!!!! Ouch!!
