Posts: 3,867 |
Originally posted by Snake2715: Not only that the dash kit will run 300+ or so and is a bear to do without the glass removed.
The sideskirts could be used but take a look at the person who you are purchasing it from. Thats not always the best indicator but it gives you an idea.
Is the oil clean on the disptick? Does the distick have burned oil on it? Are teh pedals themselves really worn? Any of these and you can assume the owner may have neglected the vehicle or it has more mileage than stated.
Where are you located?
there are a few websites besides Autotrader.com....
Auto-Rv.com automart.com cars.com Contour.org fordcontour.org etc.
The oil turns black fairly quickly. Doesn't mean the oil is "dirty" or that the car is "neglected." I would not consider this a reliable test, and I'd laugh at any potential buyer who tried to use this as a bargaining chip.
I'd show the buyer maintenance records and possibly even a recent oil analysis.
BTW, thanks Big Jim for the sideskirt advice. One of mine is a bit out of shape, by my own hand from a lift incident. Too bad I can't switch mechanics on that one.
Function before fashion.
'96 Contour SE
Posts: 2,571 |
buy it and step up to the svt world brother
Posts: 3,496 |
Originally posted by Ninety Five: The 2000 is a good year. 5 more hp, and a better diff than the 98-99 "glass diff".
2000's had the same HP as the '99.
2000 had lower displacement than previous years with higher compression ratio.
And you have got to post me a link to whne the Diff changed?
'98s are the best of the SVT bunch asthetically as they had most every item before the decontenting started. some items include larger brakes, interior clock, better dash with no warp.
Of course interior color choices were one and exterior paint was only 3.
Posts: 55 |
Originally posted by RogerB: Originally posted by Snake2715: Not only that the dash kit will run 300+ or so and is a bear to do without the glass removed.
Correct the oil gets dirty quickly. On the other hand my SVT and my sho for that mattter have almost a clean oil change everytime. I run synthetic but it held true to some degree without the full synthetic.
What I was really pointing at was the burned oil marks on the dipstick. Is your disptick really all burned looking? Mine sure isnt and neither are any of my 7 other cars.
A bunch of burned dipstick marks are not a good sign and can lead one to believe that the car was driven either with low/old oil or for extremely hot sessions.
None of what I said is sure fire way its just a general idea.
I mean some people prefer to see a spotless engine when buying a car and I dont. I personally feel as though they are covering something up. Whether that be fluid leaks or whatever.
Same thing goes with my first post its just some of the quick things I do when looking.
Posts: 3,867 |
Originally posted by Snake2715: Originally posted by RogerB: Originally posted by Snake2715: Not only that the dash kit will run 300+ or so and is a bear to do without the glass removed.
Good points. I hadn't thought about the dipstick, itself.
'96 Contour SE
