Go to Autozone, etc, and get a length of rubber hosing. they have it available behind the counter in a roll. They will cut off a length for you in whatever size you need. Get the size that is closest to the tubing and insert the two ends in to the hose (using the new hose as a bridge/connector)
Wrap with electrical tape if you wish, though it should be very tight either way.
Ray
