Page 3 of 3 1 2 3
"Absolut Rara."
"Absolut Rara."
Originally posted by striker2:
Originally posted by KingDiamond:
Has anyone tried installing the Mustang Cobra 13" brakes on a Contour SVT? It's about $400 for the front brake kit, and it's the same thing as the Baer kit for the Contour except the brackets are different (I think). So if there were brackets then it would be a cheap alternative. The Baer dual-piston calipers are just PBR calipers that are relabeled.
there is a kid at school whos SVT has cobra brakes on it rotors and all. the previous owner installed them and he redrilled the rotors to fit the contour. im not sure what he did for the bracket though. it just barely clears the kids 17s. the brakes work great though and he stops on a dime. still not sure that i would do it though.
Care to dig up some pics?
Balance is the Key. rarasvt@comcast.net
ill try to get some pics if i can but i cant give any gaurentes
97 contour gl mtx front & rear upper strut tower braces 19mm bat sway bar Koni struts w/GC knockoffs
"Absolut Rara."
"Absolut Rara."
if you can, try to take some shots of how the caliper is mounted to the knuckle.
The reason I asked is that a lot of mustang guys know that the Bear 13" dual piston brake kit which retails for $995 is the same thing as the Ford Cobra brake kit, which goes for $375.
Are you for real! Thats great. I think I know whats my next mod for my stang!
TGO Offline
Originally posted by Stazi:
The only thing you will need extra is to order the lorger brake bolts (he's knows which ones, just tell him) and 4 HARDENED 3mm thick washers.
Since this thread has been brought back from the dea, i'd lik to add that when using the FSVT brakes, longer bolts are not required. There's plenty of meat on the stockers. Seriously. Due to a fubar in ordering parts, i was forced to run stock bolts using my FSVT setup, and almost 3 years and countless emergency stops later - they are fine.
1999 Silver Frost SVT #609 of 2760 Quaife, lightened SVT Flywheel, SPEC stage II clutch, removed resonator, k&n drop in - various other goodies too.
Page 3 of 3 1 2 3
Moderated by  Andy W._dup1
