#1309850 06/19/05 02:40 AM
hey fellers
looked but couldnt find FIX for the issue some have seen with the corrosion found with disimilar metal license plate screws and the screw plates used on our trunks.
Believe the screw plates are brass whereas the screws are sumthing that doesnt like brass.
Trying to remove my plate (to rob a bank) and seem to be turning both the screw and the nut thing it goes in. WD-40 and beer have not worked.
Any tips?
Thanks!
DAve
98 SE Sport
kinda stock
I'm not sure how you will get it apart at this point. I think I would try grinding the head of the bolt off with a Dremel type tool. Once the plate it out of the way, you may be able to better address the issue.
At one time, Ford had a repair kit for this that entailed replacing the portion that the holes are in without the entire panel. I don't know if this is still available. There was a TSB with the part numbers.
Some enterprising types from CEG found another way to make a repair. After breaking out as little as possible (from like maybe drilling very small holes aroung the threaded insert), they found some "T" nuts in a hardware store of an appropriate size with matching screws/bolts and epoxied the "T" nuts into place.
When you reinstll it, put a little anti-sieze on the threads and you will not likely have this problem again.
There were posts about all of this with pictures, but it was a long time ago.
