Posts: 36 |
Ok, here is the scoop. I've looked at a few of these doors at work and I think they will fit Contiques. They are all aluminum (not some plastic rip-off). I haven't tried to track them down through a dealership yet, but http://www.mustangparts.com has them listed on their site. I called and was quoted $59.99. Not too shabby... So, who's up to see if these will fit? And if they do, I see a call to Bill Jenkins coming.....
Brad Shortt 1998 SVT Contour E1
"Stupid should hurt"
Administrator
Administrator
Posts: 5,037 |
Great find! Maybe Rara can check it out firsthand. He might be able to grab one and try it on his Contour.
Administrator
Administrator
Posts: 4,527 |
I'll see if I can dig up a loose one around work.
It's all about balance.
bcphillips@peoplepc.com
Posts: 3,584 |
If it fits I'de like one please :p I was going to pay $180.00 for the SCA one but why if that one works. Hey Rara let us know about that door fitting, I speak for alot of us when I say THANKS if it does Roger R
Roger R SVT/SHO Society SE MI rep 2000 CSVT #1253 of 2150 silver frost/midnight blue 2-8" dark blue racing stripes Mequiars...simply the best! "...and number 5, now this is the most important Rat, when it comes to making out, whenever possible, put on side one of Led Zeppelin 4" USMondeo@aol.com
Posts: 1,108 |
I would like that also looks HOT.
Kick Ass don't Kiss It
Posts: 503 |
'99 Contour SE Sport, 50k, V-6, ATX, T-Red, With Many many mods. '99 GMC Sonoma SLS, 16k, 4-cyl, Summit white, not as many mods.
Founder of Ghost Tech Racing inc. AIM-FordMondeoS "Time does not exist in this dimention; but in a time and a place we know not of..." -A. P. Stidwell
Administrator
Administrator
Posts: 4,527 |
Just fyi, the Bullitt fuel door does have the Mustang running pony on the inside of the door.
Posts: 1,108 |
That's kool with me.Does It fit? Originally posted by Rara: Just fyi, the Bullitt fuel door does have the Mustang running pony on the inside of the door.
Posts: 506 |
I would be in for something like this . . . especially because some student ripped my fuel door off at school. Cost for an unpainted replacement is $24 at local dealer. I would pay $60 for this if it fits well.
Administrator
Administrator
Posts: 4,527 |
it will fit w/ a bit of modification to the plastic around the fuel filler. I just took one of the prototype pieces out to my car and the overall size is correct, but the mounting of it requires a bit of massaging as I said above. Two small slots would need to be cut on one side, and two small holes would need to be drilled on the other side, that and you need to remove the original fuel door (duh :D) Now, do this at your own risk, I did not check what is behind the spots where you need to cut/drill, so please use some common sense and check before you start in w/ the power tools
