Posts: 2,978 |
Originally posted by svtProdigy: Originally posted by Russell-3L: buy 2 of the rear bank exhaust camshafts....problem solved
i think they have different specifications. theroretically keeps the power to around 7300 rpm roughly 45 to 50hp gain up top. I had mine cut. Having the oval port injection with this setup on pnp heads,3.o turbo...
And when will this beast be ready?
Posts: 5,810 |
Originally posted by DemonSVT: Originally posted by DanG:
That'll run really well. What do you take me for?
Think about it silly.
Inside of buying a LH exhaust and RH exhaust just buy two LH exhaust cams.
IIRC it's LH - either way he means buy 2 cams WITHOUT the waterpump drive.
Now that sounds good if they are the same...and why wouldn't they be?
Greg, do you have the specs for the mazda6 cams?
I need them!
See My Mods
Posts: 352 |
Demon, I am surprised at you.
I wouldn't buy two Bank 1 exhaust cams first off because the timing marks are off. But, that can be circumvented with a little math.
However, it wouldn't work even if you timed it properly- Where would the cam position sensor get its signal? There's no pulse nodule on the Bank 1 exhaust cam!
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
Posts: 5,810 |
Well what do they cost, the right bank and left bank cams?
See My Mods
Posts: 9,602 |
Who ever said bank 1???
LH = Left Hand = Bank 2
Originally posted by DemonSVT: Inside of buying a LH exhaust and RH exhaust just buy two LH exhaust cams.
IIRC it's LH
Now granted it appears I did not remember correctly. (rare but it happens ) The RH exhaust cam drives the pump. I just remembered it was opposite of the standard Duratec engine.
However lathing off the excess part of the camshaft is no big deal. I don't see what all the problem is with it. Several people have done it running early 3L heads with SVT cams. (and an EWP)
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,190 |
Originally posted by warmonger: Well what do they cost, the right bank and left bank cams?
retail/ cost aj57-12-440 camshaft right $295 $177.48 aj57-12-450 camshaft left $269 $161.52
I got them for cost at WILKINS BUICK MAZDA AND SUZUKI AT
225 W. ROOSEVELT ROAD VILLA PARK IL 60181 1(630)495-3564
WILLIAM PATER IS WHO SOLD THEM TO ME AT COST. THIS IS ALL FROM MY INVOICE. THE CAMS WERE NOT THE SAME OTHERWISE I WOULD HAVE BOUGHT TWO OF THE SAME WOTH OUT THE WATER PUMP. IT COST ABOUT $120 TO GET IT CUT OFF THOUGH.
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 352 |
IIRC it's LH
Um, yes... Bank 2 is the front bank, with the long cam for the 6 water pump. I would need to buy two RH cams- Bank 1- And the Bank 1 cam doesn't have the pulse nodule. Where is the miscommunication here?
Whatever- I'm just latheing (sp?) it.
Posts: 5,810 |
Good luck with that.
I'm going to be really interested in the dyno graph of this one.
See My Mods
