Posts: 352 |
Cross-post to NECO... Possible snafu. Never seen this one... Any help is appreciated.
Dan G. and his Cougar
Forged internal (Diamond & Pauter) full 3L, "Monster" Kinger F/I cut & P&P, T3/4 60 trim .82A/R ADC turbo, SPEC Stage 3, Torsen, Greddy Profec-B SPEC II, Apex'i Timer, Lots of Gauges!
Used to have: 3.0L SVT hybrid
Posts: 10,015 |
Yes, the M6 uses the exhaust cam to drive the w/p.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 352 |
Hmmm. Anyone got a hacksaw??? <searches>
What drawbacks occur when you cut it, I wonder... Especially at the horsepower promised by the headwork and ADC hybrid kit...
Posts: 10,015 |
I don't see any draw backs in cutting them. Just do it on a lathe or something suitable at holding the cams so you don't damage the lobes or bearing surfaces.
PS - my ? is, "Is it worth the hassle to do all this to use these cams?"
AUSSIE ENDLINKS $70
Posts: 352 |
According to Demon, yes- The reduced overlap of the hybrid cam setup (3L intake, M6 exhaust) is "optimal" for F/I. Supposedly the SVT cams' increased overlap will cause "boost bleeding" at higher horsepower/RPM/boost levels <extreme paraphrasing>.
Posts: 3,732 |
buy 2 of the rear bank exhaust camshafts....problem solved
Russell
Oval Port 3L Nearly Done
Posts: 352 |
 That'll run really well. What do you take me for?
Posts: 1,190 |
Originally posted by Russell-3L: buy 2 of the rear bank exhaust camshafts....problem solved
i think they have different specifications. theroretically keeps the power to around 7300 rpm roughly 45 to 50hp gain up top. I had mine cut. Having the oval port injection with this setup on pnp heads,3.o turbo...
PLEASE HELP ME GET MY CAR TOGETHER! ITS IN DAYTON OHIO! I need the motor together and in the car so i can DRIVE it! Pleeeeeese!
diamond pistons for 3.0/forsale
#702 of 2150
Posts: 9,602 |
Think about it silly.
Inside of buying a LH exhaust and RH exhaust just buy two LH exhaust cams.
IIRC it's LH - either way he means buy 2 cams WITHOUT the waterpump drive.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 10,015 |
As long as the timing marks are the same on the LH and RH camshafts, then yes, buy two of LH ones. Check the marks first though.
AUSSIE ENDLINKS $70
