Posts: 9,872 |
Everytime i stop at a red light..my revs drop to normal idle then suddenly drop lower to stalling point then going back up to normal then dropping back again to stalling point..its does thhat 3-5 times untill stabilizing in regular idle..wtf is going on, im scared my car will just die at a red light...it has before and I had to push it off
Posts: 7,100 |
You've never heard of an IAC before? Seeing as how you're no n00b, I won't walk you through the whole how to find out what to do about it, thing.  Ray
'99 CSVT - Silver #222/276
Posts: 9,872 |
Idle Air Control..what do i do about it?
buy a new one?
Posts: 7,100 |
In case you were serious:
clean it.. or replace it..
In the faqs.. also involved in the uim rebuild (which you know where the how to is for that) that I wrote.
Ray
Posts: 9,872 |
your gonna hate me for this question Ray...where is the IAC..like I did the throttle hang fix, is it along that pipe?
Posts: 7,100 |
hehee... check out the rebuild how-to.. about 70% of the way down is a blurb with a pic.. a finger pointing to the IAC.. (silver)
Ray
Posts: 432 |
Clean, lubricate, and re-install. 4500 posts ???? there has to be at least 4500 on the IAC alone...hehe. Ok which one is it. You just post and never read any posts You have a good memory, but its short You thought search was when you lost something Your almost at 5000 posts....hehehe
Posts: 1,459 |
There can be things other than the IAC that cause the fast-slow-fast-slow idle. I put a new IAC on my zetec, and it still searches up and down for the idle, so there are apparently other contributing factors. I just haven't found them yet. I bought a TPS a couple of days ago, but haven't gotten it installed yet. Maybe, just maybe..........
95 Mystique Zetec, MTX
2000 Taurus SEL 3.0L Duratec
1994 Crown Victoria LX 4.6 V8
1993 Chevy Silverado 4.3 V6
Posts: 9,872 |
Originally posted by Taasman: Clean, lubricate, and re-install. 4500 posts ???? there has to be at least 4500 on the IAC alone...hehe. Ok which one is it.
what do I use to lubricate?
Posts: 4,140 |
I have a used late-model IAC if you're interested. It didn't fit my '95 easily, but I tested it and it works fine. PM me for details.
