Posts: 1,899 |
when would be the most ideal time of the year/day to go to the track to get the best runs in?
Posts: 9,602 |
The Winter. Other than that during the day in the early spring or late fall. Any time the temp is cool, the humidity is low, and the BP is sky high.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 1,303 |
its been a long time sinse we learned this in school, but typically if the BP gets higher doesnt that mean rain is a-comin?
Goonz12: <---tries on mommy's cloths
Posts: 299 |
Opposite.
As BP lowers, a low pressure system comes in, bringing moisture. High pressure keeps moisture out.
Posts: 2,116 |
I think the best time and place would be northern MN in Jan. 30-60 below...is that cold enough air for you people?
95 SE MTX
svt exhaust
intake
deer killer
Posts: 9,602 |
Originally posted by elraido: I think the best time and place would be northern MN in Jan. 30-60 below...is that cold enough air for you people?
Too cold actually. Once the temperatures drop below around 40 degrees the combustion efficiency starts to drop.
2000 SVT #674
Posts: 4,140 |
Originally posted by DemonSVT: Originally posted by elraido: I think the best time and place would be northern MN in Jan. 30-60 below...is that cold enough air for you people?
Plus you'd never get traction. Even Hoosiers would be rocks.
I'd prefer:
45-50 deg F dry as possible hot hot sun to warm the track and tires up light breeze the keep the air above the track cool
That should give traction and power in the best combination.
Although I don't drag, anyway. I actually like the rain for autocross, so my Fuzions can show the Azenis up!
