Page 2 of 4 1 2 3 4
#1307093 06/17/05 05:17 PM
X
X
OK, how about a fuel pump cutting out and needing to reset the battery in order to get it working again to start the car? That will need replacement, right? Too bad mine is a return system.
"Speak English... I am speaking Engrish..." Steve Chang 99 Silver SVT Contour #196 (Garaged) 06 Dark Blue Pearl Fusion SE V6 (Daily) 05 Dark Shadow Grey Freestyle Limited AWD
#1307094 06/17/05 06:18 PM
lizard Offline OP
when im down to a 1/4 tank it feels like im out of gas struggling to even get up to 60mph
2000 contour V6 ATX BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
#1307095 06/17/05 06:42 PM
Lizard: your problem is the dirty sock filter on the lower half of the pump. Access the pump via the rear seat, and remove the plastic sock piece. Research the dirty sock for pictures and a how-to.
Ray
#1307096 06/18/05 02:20 AM
Ray,
Do you know if the sock filters can be bought separetly yet. When I switched over to the FSVT pump you couldn't but that was last fall. I just went into the tank last week to clean the sock filter...again. Also is it safe to just do without the filter? I got rid of the round screen on the bottom but I put the sock one back on.
'00 T-Red TourSE 2.5L ATX Foglight Mod,Optimized Y-Pipe & TB, FSVT F/P,RU-3530 http://www.cardomain.com/memberpage/688552
#1307097 06/18/05 02:38 AM
ditch the sock filter.. there is an internal one as well to keep larger particles (big enough to harm the pump) out. the sock is just TOO fine.
IFAIK, you can't purchase the sock seperately, and the newer ones, that you CAN purchase seperately don't work as a swap-in replacement.. you'd have to have a newer style pump to accept that style sock.
Ray
#1307098 06/18/05 06:28 PM
lizard Offline OP
should i remove the round screen on pump at the same time
i have read that get clogged too
#1307099 06/20/05 05:49 PM
Well you know you know the pump is bad anyway. WTF?!
#1307100 06/22/05 12:56 AM
W
W
Originally posted by lizard:
my fuel pump is over heating
if i have less than 1/2 tank it has trouble reving high
your right i could just use stock but this one is better
What tells you this? Is this common with a returnless?
Did you also check the fuel filter?
#1307101 06/22/05 03:23 AM
Yes.
The original returnless fuel pumps and MAINLY prefilter were prone to starvation when around 1/4 tank of fuel or less.
I removed my prefilter years back now after having that problem and haven't had a problem since. I was expecting to have to have put in the SVTF pump long ago.
#1307102 06/27/05 12:49 AM
lizard Offline OP
ok i fix the fuel pump issue that i was having but in the process of doing so i created another.
now my fuel gauge is always on full, how can i fix this
Page 2 of 4 1 2 3 4
