Posts: 1,225 |
OK, how about a fuel pump cutting out and needing to reset the battery in order to get it working again to start the car? That will need replacement, right? Too bad mine is a return system.
"Speak English... I am speaking Engrish..."
Steve Chang
99 Silver SVT Contour #196 (Garaged)
06 Dark Blue Pearl Fusion SE V6 (Daily)
05 Dark Shadow Grey Freestyle Limited AWD
Posts: 451 |
when im down to a 1/4 tank it feels like im out of gas struggling to even get up to 60mph
2000 contour V6 ATX
BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
Posts: 7,100 |
Lizard: your problem is the dirty sock filter on the lower half of the pump. Access the pump via the rear seat, and remove the plastic sock piece. Research the dirty sock for pictures and a how-to.
Ray
'99 CSVT - Silver #222/276
Posts: 219 |
Ray, Do you know if the sock filters can be bought separetly yet. When I switched over to the FSVT pump you couldn't but that was last fall. I just went into the tank last week to clean the sock filter...again. Also is it safe to just do without the filter? I got rid of the round screen on the bottom but I put the sock one back on.
Posts: 7,100 |
ditch the sock filter.. there is an internal one as well to keep larger particles (big enough to harm the pump) out. the sock is just TOO fine.
IFAIK, you can't purchase the sock seperately, and the newer ones, that you CAN purchase seperately don't work as a swap-in replacement.. you'd have to have a newer style pump to accept that style sock.
Ray
Posts: 451 |
should i remove the round screen on pump at the same time i have read that get clogged too
2000 contour V6 ATX
Posts: 21,197 |
Originally posted by xchang: OK, how about a fuel pump cutting out and needing to reset the battery in order to get it working again to start the car? That will need replacement, right? Too bad mine is a return system.
Well you know you know the pump is bad anyway. WTF?!
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 5,810 |
Originally posted by lizard: my fuel pump is over heating if i have less than 1/2 tank it has trouble reving high your right i could just use stock but this one is better
What tells you this? Is this common with a returnless?
Did you also check the fuel filter?
See My Mods
Posts: 9,602 |
Originally posted by warmonger: What tells you this? Is this common with a returnless?
Yes.
The original returnless fuel pumps and MAINLY prefilter were prone to starvation when around 1/4 tank of fuel or less.
I removed my prefilter years back now after having that problem and haven't had a problem since. I was expecting to have to have put in the SVTF pump long ago.
2000 SVT #674
13.47 @ 102 - All Motor!
Posts: 451 |
ok i fix the fuel pump issue that i was having but in the process of doing so i created another. now my fuel gauge is always on full, how can i fix this
2000 contour V6 ATX
