Posts: 451 |
i have searched already and i found the svt focus smart pump my question is will that fit in my 2000 tour se/svt and do you kno of any good fuel pumps that will last through heavy lead footing
2000 contour V6 ATX
BAT suspension kit, k&n filter, SVT TB, SVT UIM, SVT LIM, MSDS headers, MSDS Y-pipe, SVT dual exhaust, Custum burned ADC chip, 7000k HID's, 200 amp HO alt, custom gauges, and 17" rims
Posts: 47 |
thats what im wandering. i have a 99 csvt that doesnt have a returnless line and need to upgrade my pump for nitrous. what is bigger pump that will fit right in.
#510 of 2760, KKM true rev induction, optimized y pipe, exhaust,custom tuned Diablo chip, and BAT lowering springs, DMD, optimized throttle body.
Posts: 1,356 |
In (IIRC) Mid-Late 99 they switched over to the returnless setup. My late 99 has the returnless setup.
If its returnless, the FSVT pump will work. If not, I don't think it will.
I beleive the FSVT pump puts out like 255LPH and the stock pump is 155LPH.
1999 Mystique LS V6
Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
Posts: 451 |
is it a direct swap or do you have to do some modification
2000 contour V6 ATX
Posts: 10,015 |
WHy are you changing it - is it REALLY necessary?
Seems like a lot of your posts are asking question about mods you don't need.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 451 |
my fuel pump is over heating if i have less than 1/2 tank it has trouble reving high your right i could just use stock but this one is better
2000 contour V6 ATX
Posts: 10,015 |
No, I just thought you wanted to do it cos you thought it would net you power or something.
If it's screwed and you have a returnless car, then yeah get the FSVT pump from Bill Jenkins.
AUSSIE ENDLINKS $70
Posts: 21,197 |
If you need anyone to do a fuel pump I know a guy in Grand Rapids. His name is Todd.  It's not a direct swap. You have to swap over the sock on the filter. It's all in the FAQ.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 451 |
fuel pumps are pretty easy to do
2000 contour V6 ATX
Posts: 7,100 |
less than 1/2 and trouble revving.. sounds like a dirty sock inlet on the lower half of the pump, to me. no need to replace it, just for THAT symptom.
Yank the sock, leave it out.
done.
Ray
'99 CSVT - Silver #222/276
