Posts: 1,165 |
OK.
Here is what you do. Cause I've been there.
I'm sure you've already searched the internet to steal code from someone else, so I'm not going to bother suggestting that.
Not sure what the problems are like, but if you can get away with getting some from other students and not being caught. Do it.
Or, and this is probably the best(ethically speaking) route. Explain to your prof what happened and see if they will give you another day. MOST professors will. But I would definitely turn SOMETHING in tomorrow. Don't go in empty handed. Give them an exact time you will have it for them tomorrow, and then make sure you get it to them by that time.
Good Luck!
I live in Detroit, I couldn't give a **** how good my car is in the "twisties."
"I could use a hundred people who don't know there is such a word as impossible."
~Henry Ford
Posts: 2,728 |
I like those suggestions 99SVT. I'll probably combine them and ask for another day just for more time to "get help". I've searched the internet, but its such a pain in the ass right now with Comcast. My cable modem craps out about every 2 minutes on average, if that. They're sending someone out on Sunday with a new one, but until then I'm just screwed for using the internet. So my searches go in 2 minute spurts, which usually result in a bunch of nothing
'03 SRT-4
50 trim turbo + support
Posts: 562 |
If they give you another day...look up a drink called Bawls. Bawls is a HIGH caffeine energy drink that is favored by gamers and programmers and will help you stay up and finish them if it comes to that. Remember, Bawls is your friend.
'99 Spruce Green SE "Sport" 'Tour, 2.5L MTX...80K and running like it just rolled off the lot.
Tryin' to add an extra .5L ASAP
Posts: 3,028 |
Good Luck!
99SVT has it. Explain it to the professor. The worst he could do is call you a liar...
Just think man, what if you had been a Microsoft programmer, and were like two lines of code away from completing Windows 2Million and went to get some coffee and on getting up, you touched the ESC button (somehow) and poof, it's all gone...At least it's just a grade...
Posts: 1,341 |
Quick! Grab the closest bowl or bong. Pack. Smoke. I bet you'll be alot more relaxed and will be able to think of a brilliant solution.
Posts: 624 |
Originally posted by SVTcontourSVT: Quick! Grab the closest bowl or bong. Pack. Smoke. I bet you'll be alot more relaxed and will be able to think of a brilliant solution.
Good answer!
I don't "mod" I just fix what breaks!
98 CSVT #2527 T-Red (Limping)
98 CSVT #2228 T-Red (Donor)
98 SE Sport ATX V6 (Running again)
If swimming is good for your figure, explain whales to me!
