Posts: 411 |
Well, here's a view of where the intermediate shafts go. Are there any Quaife owners out there who remember what it looks like installed?
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
Born on March 16, 1998
"If trees could scream, would we be so cavalier about cutting them down? We might, if they screamed all the time, for no good reason."
Posts: 3,732 |
Russell
Oval Port 3L Nearly Done
Posts: 411 |
No worries- haven't bought it yet!
It is in excellent condition though, so pending inspection, I will be getting it at a substantially lower cost, too!
ADC will then be getting a call from me shortly thereafter. I just hope the Torsens aren't still on nat'l backorder.
-Chuck Dienzo
Black 98.5 E1 SVT
#5022 of 6535
Posts: 9 |
Not true LSD is suppose to lock the the axles going into the diff. case, if the you spin the right wheel forward and the lift wheel spin backward its a open diff. Meaning the the axles are not lock. Because of the extreme force put on the wheel when turning is when the wheel move at different speed and slips. (Hints the name Limit Slip Diff.)
Posts: 712 |
wow i never knew that
1998.5 Diamond White Pearl SVT (#4725)
custom exhaust/intake k&N/mod'ed y-pipe
slotted rotors/greenstuff pads/SS lines
cougar trans/FSVT shift tower/Torsen
16lb. flywheel
18" Velox VX-8's with some rubba bands
Posts: 10,015 |
Originally posted by Lloyd_Motors: Not true LSD is suppose to lock the the axles going into the diff. case, if the you spin the right wheel forward and the lift wheel spin backward its a open diff. Meaning the the axles are not lock. Because of the extreme force put on the wheel when turning is when the wheel move at different speed and slips. (Hints the name Limit Slip Diff.)
Sorry buddy, but you're 100% wrong. Techinically a Helical differential STILL behaves like an open in this instance, i.e. spin the wheel when both are off the ground. So yes one will spin in the OPPOSITE direction to the other with a Torsen or Quaife.
The torque CONTROL with these diffs only works when both wheels are loded, i.e. touching the ground.
Trust me, I have 6 years of axle engineering experience.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 4,140 |
check out the links from this, under "LSD". A lot of good info on those pages.
http://abigmess.blogspot.com
Posts: 9 |
Yea your right, I forgot about that, but im sure you know there are more than one type of design. So with respect i wouldnt say im completly wrong.
Posts: 10,015 |
Well seeing as we're talking about and MTX-75 - yes you're completely wrong.
AUSSIE ENDLINKS $70
Posts: 4,140 |
Originally posted by Stazi: Well seeing as we're talking about and MTX-75 - yes you're completely wrong.
Not if he's talking about the "Phantom Grip". Theoetically the clutch-diff type action WOULD turn the other wheel the same way, if the car was in neutral.
But that's not what we were talking about, and that's a piece of crap anyway, so...
