Page 2 of 4 1 2 3 4
Y
Y
Originally posted by racerbox77:
AIR temp not coolant temp.
D'oh!
Mark
another thing people could do is what demon does and he actually raised the back end of the hood just a tad to let hot air escape.
EDIT: heres a pic of what im talking about.
thats using your noggin Demon. I like that, I think tonight Ill throw a couple washers in between the hood and the hinge.
99 SVT "nice" 14.67 @ 92.6 mph (street trim) FOR SALE contact KEVIN.BOX@CINGULAR.COM http://www.cardomain.com/ride/1592122
that looks pretty sweet.
'95 CGL ZMTX - DOB: 8/94 - Daily Driver - 271k & counting - Ractive muffler,MSD ignition coil,KEM 8mm wires,Pre98 SE 7 spoke rims,KVR CF brake pads,Post98 sail panels,Sony Xplod HU,Pioneer 3-way 6x9's '89 Mazda B2200 - Under Construction
9
The little things are what makes the difference between a 14 second car and a 13 second car...
1999 Mystique LS V6 Alpine CDA-9807, Rear deck sub, Opt. TB, K&N RU-3530/MAF adaptor, custom heatshield, FSVT 17's, SCT 4-program chip, Eibach's/ST200's, Hella Fogs...
I've done that on my hood (raised it)..
works wonders.
Ray
Id do that if it didnt look ghetto
That's fine.. It can look "ghetto" while I outperform you.
You really can't tell THAT much, it isn't THAT high.
Ray
It's not too bad.
That picture shows it at the worst and most noticable angle. Looking up from the ground level.
You can look at the newer pics on my site and see that even with the camera moved up just 1 foot the gap closes.
The picture from the front doesn't even show the gap.
Either way I saw big drops in underhood temps with the various mods I have done. (which include that & removing the weather seal)
Also the thinking behind why the weatherstripping is there is in correct.
For instance the air above the cowl is low pressure as well. Hence the entire idea for cowl induction hoods. If they wanted the engine bay sealed they'd weather strip the entire hood. The seal on the cowl is to stop rain from getting in. Even with it gone there still is the plastic channel the stops rain anyway.
I respectfully disagree, not only because my info comes from "the great" TH, but because the cowl is a high-pressure zone, and that's why cowl-induction (as well as cabin venting) works.
When a moving gas like air is brought to a halt, there is an attendant rise in pressure (the kinetic energy is converted to static pressure).
Bernoulli's equation illustrates this:
P + (rho*V**2)/2 = constant
where:
P = air pressure
rho = air density
V = air velocity
When you decrease the air velocity, pressure must increase to keep the quantity
a constant.
The air flowing over the side edges of the hood would create a low-pressure condition at the seam, which would suck air out of the engine bay (Venturi effect). This contributes not only to cooler air, but lower pressure behind the radiator.
The fact that the rear "weather seal" also keeps water out is certainly a plus, but I seriously doubt that's its only function.
Best thing is to remove the hoodliner, but leave the seals in place.
Also, it may be true that your performance is improved, or that your 1/4 mile time is better, somehow, because of your mods. Frankly, I couldn't give a rat. If that's your only goal, then you're doing the right thing.
I'm not Chicken Little, saying your engine will explode if you do this. (Obviously not the case.) It may be that the overall effect is minimal, or that the cooling fan compensates, somewhat, by running more often. All I'm saying is that these simple foam pieces serve a purpose.
More backup info:
http://www.hardcore50.com/Articles/georgeklass/TheBigWind.htm
Originally posted by George Klass:
The actual high pressure areas on the front of your car, the places where you can get increased or high speed airflow, are typically at the front part of the hood (not the middle of the hood like the old Pontiac Firebird or Mach I shaker scoop) and the area where the rear of the hood meets the windshield (cowl area). The cowl is the area where your fresh air or vent inlets are located from the factory, and it�s not an accident.
Function before fashion. '96 Contour SE "Toss the Contour into a corner, and it's as easy to catch as a softball thrown by a preschooler." -Edmunds, 1998
Page 2 of 4 1 2 3 4
