I
I
i have a teal '96 mystique..i dont mind the teal color so much as i mind the grey & pink stripes going down both sides of the car..is there a safe and cost-effective way i can remove these stripes by myself without damaging the paint or leaving any sticky residue behind? any help or suggestions you guys could offer would be appreciated..thanks for reading!
F
F
Your paint may have faded though and not faded behind the stripe...It probably won't be too noticeble on your color of a car....Try just peeling them off starting with your nails. You can also heat them with a heat gun or the wif's hot a** blow dryer. To clean up all the sticky stuff use 3M General Purpose Adhesive Remover available from any body and paint shops or Napa! Lots of elbow grease.
Chad Williams
chad5160@usa.net
[b]'99 SVT Frost Silver[\b] #812 of 2760 Born on Jan. 12, 1999
Quite a few mods [b]*)[\b] and some big tunes. Roaming the streets of Denver blowing exhaust at imports!
Chad Williams
chad5160@excite.com
'99 SVT Frost Silver #812 of 2760 Born on Jan. 12, 1999
F
F
My gawd...look at my sig I tried to change....I know I am not a retard...It's late ...Im tired...Sorry...Argh!
Chad Williams
chad5160@usa.net
Quite a few mods *) and some big tunes. Roaming the streets of Denver blowing exhaust at imports!
Chad Williams
chad5160@excite.com
your screen name? And yes Im ok r u ok?
Josh
Aka Spectra SVT
02 Dark Highland Green F-150 XLT
Mods: Gunrack and cowboy boots
I
I
dam Mystikal35 u beat me to it
99 SE SPORT Navy blue
2.5 ATX
Moon Roof
CUZO Hyper white high/low
#885
BNM GAUGES
KKM True Rev
Magnaflow exhaust#14830
Ultraflow Res#17230
Contour windshield banner
Mine is Electric Red Metallic. Will that show if the paint is discolored a bit? It is darker and more red than the later Toreador.
Dan Parmelee
TheContourGuy@aol.com
95 SE ATX
KKM
24V HIGH OUTPUT badging
SVT E0 wheels/tires
yellow calipers
CEG stickers
OF's TH fix
HyperWhite high beams
CoolBlue low beams
drilled metal pedals
faux metal grille
removed hoodliner
01 Infiniti I30t
95 Ford Windstar LX
http://hometown.aol.com/thecontourguy/contour.html
Dan Parmelee
1999 Acura Integra SiR-G coupe
"I heard Affleck was the bomb in Phantoms"
"Word, bitch! Phantoms like a muhfuka"
I
I
well i only had a chance to get the rear passenger panel done today before work but so far i like the outcome..there is no difference in the shade of paint when i remove the stripes and they come of very easily without leaving any residue behind..although i'm going to have to give it a good washing to get rid of the dirt that's collected at the edges of where the tape used to be, other than that it looks like smooth sailing...thanks guys
